Planes => Sports => Topic started by: Fred on April 07, 2009, 08:45:01 AM
Title: BigLift I - Rebuild
Post by: Fred on April 07, 2009, 08:45:01 AM
Tow plane is back on track !
Yesterday evening, started the re-covering of the beast.
Will be all bright yellow for better visibility  :D
Slowly but surely, I hope to have it ready for Retroplane along with the electric one.
(http://www.gliderireland.net/forum/images/uploads/Fred/DSCF6892.JPG)
(http://www.gliderireland.net/forum/images/uploads/Fred/DSCF6893.JPG)
(http://www.gliderireland.net/forum/images/uploads/Fred/DSCF6894.JPG)
Post by: DennisZ on April 07, 2009, 11:16:51 AM
Hi Fred,
how much power tow plane is expected to have ?
also what mods have to be made to convert "ordinary" plane to a tug ?
I'm thinking maybe my electric monster can be used for that ?
http://www.leinster-model-flyer.org/wordpress/wp-content/uploads/2009/03/dscf4146.jpg
80" wingspan
Dennis
Post by: Fred on April 07, 2009, 12:18:00 PM
Hi Dennis,
In general, well, that depend of what you have to tow !
The BigLift will go with a 26cc first, and if there is some interrest, I will certainly upgrade to a 50cc to go with bigger gliders.
The first thing you need, is a stable platform (the BigLift is born as a tow plane...) and power (tork). After that, everything else is in the way you fly the tow plane... Tow pilot is a R/C category on its own.
Then, of course, you need a release hook, as near as possible of the CG (we usually put it at the wing TE). Tow hook must be remotely controlled for the release.
I guess any planes can be converted as a tow plane, as 50% of the towing success are from the pilots, the rest, is the machine in my opinion.
Post by: DennisZ on April 07, 2009, 12:31:58 PM
Thanks Fred.
my plane certainly is nowhere near 50cc.
about tow hook: does it mean after glider has released its end, tug drops another ?
Post by: Fred on April 07, 2009, 12:37:10 PM
No worries, any power will do. That will only limit the weight of the glider you can tow !
My electric one will be for gliders up to 2 kg for example...
For the tow hook, no (well, not necesarely. I know some tow plane pilots who release the line before landing on a low pass...) but that is more an essential safety feature.
If the glider have a problem, the tow plane can always release. You save the plane...
Post by: joe on April 09, 2009, 10:36:55 AM
Good colour Fred. I think we will see that in the air.
When do I get my hands on it?? :D  :D  :D  :D
Post by: Fred on April 09, 2009, 11:49:46 AM
On my dead body !  :P
Or when I want to fly my gliders really...  :P
Post by: Fred on April 20, 2009, 08:49:13 AM
The BigLift now sits on his wheels !
Servos are in the fuselage too !  :D
And no photos! Tonight!
Post by: Fred on April 21, 2009, 11:02:03 AM
So, here is the progress so far  :D
A little bit of work every now and then...
Going to be visible I'm sure...  :lol:
(http://www.gliderireland.net/forum/images/uploads/Fred/DSCF7038.JPG)
(http://www.gliderireland.net/forum/images/uploads/Fred/DSCF7040.JPG)
(http://www.gliderireland.net/forum/images/uploads/Fred/DSCF7042.JPG)
(http://www.gliderireland.net/forum/images/uploads/Fred/DSCF7044.JPG)
Post by: Happy Days on April 21, 2009, 17:56:32 PM
Corrrr, you've certainly got a big one Fred! :shock:  :oops:
Post by: Alan_Perse on April 21, 2009, 18:56:08 PM
Hey Fred. Is that the old MPX Big Lift.
Post by: Fred on April 22, 2009, 07:22:05 AM
Hey there  :D
Wel Keith, not that big, but all square, that make it bigger than that thing really is I think !
On the nose, a 26cc (originaly, this plane towed hundreds of gliders with a 15cc...), but if we have lots of interrest, I will go for a 45 / 50cc in the future... (The 26cc with the 18x6 pull 5kg static...)
Alan, this is an original vintage BigLift from Multiplex... About my age !  Pure unobtainium !  :D
Full functions, at the time, we used to put a video camera on it (there is a window on the belly), tow hook, top (gliders) and bottom (parachutes, banner) etc etc... All the linkage were push/pull with steel cables, but now updated to a more modern standard !  :)
Post by: Stephan on May 12, 2009, 20:08:30 PM
Fred, could you measure on your BigLift the incidence? Has your BL ailerons and flaps, if yes you could measure them  too  :D
Stephan
Post by: Fred on May 13, 2009, 16:55:29 PM
Hey Steph, sorry for the late reply !
Will do asap! Have to set it up in the garden to do it.
But the wing incidence pins should be built in no?  :?:
Post by: Alan_Perse on May 13, 2009, 17:02:16 PM
Maybe Stephan means the incidence between the wing and the tailplane?  :?: :?:
Post by: Fred on May 13, 2009, 19:38:28 PM
Hi Alan,
Yes, but the incidence pins are built in as far as I remember, so cannot be changed without quiet extensive work.
Rain tonight Steph, Hopefully tomorrow  :D
Post by: Stephan on May 13, 2009, 22:19:46 PM
Quote from: "Alan_Perse"
Yes exactly (longitudal dihedral), my Big Lift was already build partialy when I got it, because I am a cautious person I verfied it and got 3°. I changed it now to 2°.
The wing dihedral I think should be 2° but I was not able to get this. I have now 0.8°, but thats ok. I cannot get more because I added some plug in mounts which are not designed originaly in the wings.
Stephan
Post by: Fred on May 14, 2009, 20:55:19 PM
Hi Stephan,
Just checked, and I have 2.5°
Cannot check the diedhral, but looks like 2° to me too  :?:
Post by: Stephan on May 15, 2009, 08:13:56 AM
Hi Stephan,
ok, so I am not to bad. Have you checked the depth of the ailerons and Flaps too  :?:
Stephan
Post by: Fred on May 15, 2009, 10:50:04 AM
Feck no!
Sorry forgot, I do that tonight!
Post by: Stephan on May 16, 2009, 17:29:59 PM
Hi Fred
here it is my baby, first assembly today, I think it will fly end of May.
Cheers
Stephan
(http://www.gliderireland.net/forum/images/uploads/Stephan/IMG_4884-c550.jpg)
Post by: Fred on May 16, 2009, 21:48:27 PM
Looking good Stephan !  :clap:
Here are all the dimensions for you for the ailerons and flaps :
(http://www.gliderireland.net/forum/images/uploads/Fred/DSCF7170.JPG)
I hope to have mine done sometimes in June now  :oops:
Post by: Stephan on May 16, 2009, 23:42:57 PM
Thanks Fred. This evening I mounted the engine and I am quite happy. It's easier than I thought it to be.
Steph
