Author Topic: Multiplex Filius build  (Read 2859 times)
« on: February 05, 2022, 17:34:48 PM »
Time that glue some wood!
This time, it is an oldie. Well, not really! Let say there is only a couple of them, and mine is the only ones ne built :)
So, proper wood kit, jedelsky wings, and optional power pod.
Let’s go, but not much to say really, it is just a matter of following the plan.
I started with the wing. Jedelsky so they are quickly done and does not bring any difficulties really.
Re: Multiplex Filius build
« Reply #1 on: February 11, 2022, 19:46:03 PM »
Fuselage doesn’t call for much comments. It’s a glorified box  ;)
Everything fits perfectly so it took roughly 30 minutes to build.
For the tail end, same, balsa sheets are cut and just glued flat. And that’s it!
Everything is then covered white as I want to do the original scheme  ;)
Next, glue the tail end, canopy, servos and we are good to go!
