Author Topic: FPV in IRL  (Read 133081 times)
FPV in IRL
« Reply #90 on: May 13, 2011, 07:12:10 AM »
Hi Bumper, I am unsure of the legal aspect of transmitting video in the South of Ireland.
I would suggest that you contact MACI , this is the governing body for RC in the South.
They are there to help you ! and will give you guidance.
zg3409
Radio and video sending
« Reply #91 on: May 16, 2011, 18:44:49 PM »
I have read with interest the messages so far. I have an amateur radio licence and I have been involved in sending TV pictures for 10 years.
From a techical point of view
1249Mhz transmitters are illegal in Ireland and we use 1240 -1300 (and received up to 1320) in Ireland so you will interfere with us! We report interference and can track down messers. We have already has to report and remove illegal commercial security cameras from our allocation.
MPT1349 (probably comreg typo) is actually on 1394Mhz and it seems to be exempt up to 500mW (this is a lot of power for a model aircraft)
See:
http://www.sourcesecurity.com/docs/fullspec/ACFA94.pdf
and
http://www.icecom.is/gogn/18931003.pdf
Generally I would not really advise it for your use as there may be high power users in every city which could cause interference. Generally the 5.8GHz stuff is better but is more expensive. A good camera is very important also.
We have a website with info (not 100% up to date)
http://www.iatc.ie
and there are people involved in Dublin, Cavan, Waterford and Cork. We mainly have equipment at the top of mountains which listens for a TV signal, then re-broadcasts this on a different channel.
For your use I would also suggest using directional receive aerials on the ground end as these are perfectly legal and can help the signal. The down side is someone needs to point the thing.
I am available to offer advice, give help and demo gear if needed. There is lots of good and bad gear out there so ask somone for advice. I aI (along with others) are working on text overlay on the video so you can ddiaply things like altidue, position (from GPS) and time/date etx. We are also conidering auutomous flight in the future (pilotless) I live in Bray Co Wicklow, so we can meet.
We have very high power transmitters and very, very sensitive receivers. I am also working on digital TV transmitters. These would be more useful for semi professional use or from a full size glider to ground. We can use them "aeronautical mobile" and you will hear a hot air balloon on our frequencies from time to time. The legal aspect is to stop interference with other users and your own aircrafts equipment.
Regarding cost we normally build our own stuff, or modify off the shelf gear. It's only a hobby after all.
Dan 087-7731120
Bray, Co Wicklow
liutas009
FPV in IRL
« Reply #92 on: May 18, 2011, 22:13:35 PM »
your system from the link is not made for airplane. Its to heavy.
The only made transmitter video  system is 900mhz, 1.2 ghz 1.3 ghz 2.4ghz and 5.8ghz.
We need power for long range. As im doing aerial video and photography i need to fly 1-2km distance to get a shot.  so its complicated.
Re: Radio and video sending
« Reply #93 on: May 19, 2011, 10:57:58 AM »
Quote from: "zg3409"
See:
and
http://www.iatc.ie
Dan 087-7731120
Bray, Co Wicklow
Hi Dan,
Great to see more people involved in these projects in IE. :)
One question, have you considered "inejecting" the "text" into the video stream but using the method used by the broadcast teletext? (vertical blanking interval )
I've been trying to find other ways to have telemetry without using a extra downlink or by extracting data from the video overlay.
Nando
zg3409
FPV in IRL
« Reply #94 on: May 19, 2011, 21:34:28 PM »
There was a teletext encoder available for hobbiests but the company that sold it no longer does it.
With digital transmission, which I am working on, it is theoretically possible, but the off the shelf units just allow setting of station name etc.
There is some guys in the UK working on PC based transmissions where every aspect can be varied, and they hope to use it for one way data transmission.
Your best best would be to use a seperate 433.92Mhz serial modem to send the data. These are dirt cheap and easy to interface with. Some have built in error correction and are fast and good. It's what I would use.
Dan
FPV in IRL
« Reply #95 on: June 20, 2011, 12:05:13 PM »
Just sharing a small test done this weekend.
[youtube]http://youtube.com/v/b-TJS_5cacM[/youtube]
Lesson learned, never trust the chinese when it comes to crimping plugs.
Had to redo all the wiring for the video part, as the plugs were badly crimped and were source of video black outs.
FPV in IRL
« Reply #96 on: June 30, 2011, 08:31:47 AM »
Nice video Nando.
liutas009
FPV in IRL
« Reply #97 on: June 30, 2011, 19:42:56 PM »
Finaly, got full set up on my plane, so can fly with maximum safety taking pictures around the country.
Here are few samples done in past few days
FPV in IRL
« Reply #98 on: July 01, 2011, 07:09:06 AM »
FANTASTIC !
Liutas this is exactly what I would like to acheive with my camera and plane.
Is your plane now FPV ?
liutas009
FPV in IRL
« Reply #99 on: July 01, 2011, 08:46:15 AM »
Thanks, it is full fpv sistem.
Without it wont be able to get clear shot :)
FPV in IRL
« Reply #100 on: July 02, 2011, 23:05:29 PM »
Great pics Liutas!
Those are making me consider installing the FPV system on a plane as well. :)
This weekend I went for further tests.
Solid signal and image and I should get the new "toy" I'm developing finished soon.
It's a ground box that connects to the video RX and tells me the signal strength and voltage
levels. So far is just on a LCD but when the code is finished it will give sound alarms as well.
liutas009
FPV in IRL
« Reply #101 on: July 07, 2011, 22:09:47 PM »
verry good. Im waiting for Bixler form HK, this is gona be my fpv fun plane ;)
FPV in IRL
« Reply #102 on: July 08, 2011, 07:09:53 AM »
Hi Luitas, I am waiting on dry weather to test my ugly home build camera platform plane.
Made from foam scraps,ply wood from a scrap caravan, tail feathers from an election poster, and part of a fishing rod that I recovered from the skip.
This plane cost me pennys not pounds.
Will it fly ?
liutas009
FPV in IRL
« Reply #103 on: July 15, 2011, 07:30:51 AM »
Quote from: "Richard Boyd"
Will it fly ?
Man, im not specialist in building scrap planes, but anything with wings and motor can fly :). I think its cheap enought to by ARTF from HK. I just ordered BIXLER for 49$ .
And this plane will definetly fly. Great paltform for FPV.
FPV in IRL
« Reply #104 on: July 15, 2011, 07:57:22 AM »
Hi Liutas, my scrap plane now is in the rubbish bin !
First flight was not good !
I just returned from flying holidy on the North Coast and weather was amazing. Sad that I had no platform to take foto.  :!:
I read very good reports about Bixler for FPV, very exciting to get new plane.
