Gliders => Scale => Topic started by: Fred on November 02, 2007, 08:46:05 AM
Hi there,
So, here is my new project for the beginning of the winter !
During Retroplane, we were talking and showing the 1/4 scale Ka3, and between 2 glasses of schnaps :mrgreen: some of the German guys suggested that the Ka3 is fine, but bigger, that will be better ! :P
Ah well, sometimes, it's hard to say no to things like that ! :D
So, I have redraw the smaller Ka3, change a few bits and pieces, and here we go !
Slow start, let's say a warm up, with the tail mounting pieces.
The parts :
(http://www.gliderireland.net/forum/images/uploads/Fred/piecesupportstab.jpg)
And 10 minutes later :
(http://www.gliderireland.net/forum/images/uploads/Fred/supportstab.jpg)
And that's it for today ! Next on that piece is to glue the carbone tubes for the V tail.
Next... Well, I have to make space in the garage now, and I'll certainly start the fuselage.
Looks nice Fred :D . Can't wait to see it fully built. You can't beat laser cut parts. I'm telling you, my next project will have to be Laser Cut. Cuting out the parts your self is like :!: :!: :!: :!: :D :D
Thanks Alan :D
Well, it's cutted, but you still need to glue all the parts together... That put dirt on my fingers :P
Sunday, busy day in the workshop, with the building of the fuselage.
A looooong 5x5 hardwood strip is placed on the plan. Everything is aligned with a laser and fixed to the workbench.
Then, all the formers are glued to the wood, checking at each time the alignment :
(http://www.retroplane.net/forum/images/uploads/loopingfred/couples1_101.jpg)
Of course, you also need to check that evrything is square !
(http://www.retroplane.net/forum/images/uploads/loopingfred/calecouples_153.jpg)
And we glue everything slowly, making sure everything is straight
(http://www.retroplane.net/forum/images/uploads/loopingfred/couplesalignement_410.jpg)
Then, we can glue the wing support on the fuselage
(http://www.retroplane.net/forum/images/uploads/loopingfred/cabane_212.jpg)
Then, the next job is to glue all the 5x5 hardwood strips to the fuselage...Twice ! because I glue a first 5x5 strip, then, once dried, I glue a second one on top. Easier to bend, and once the second one is glued and dry, this is, well, I think, much stronger than a single 5x10 strip.
Of course, you glue each strips doing each side at the time (symetric and avoid the fuselage to go banana ! :P)
And you can check that everything is square using the laser
(http://www.retroplane.net/forum/images/uploads/loopingfred/laser_783.jpg)
Once dry, you can move the fuselage to have a first overall look at the beast !
(http://www.retroplane.net/forum/images/uploads/loopingfred/fuselage_474.jpg)
So, next, finishing of the fuselage webing, and another few bits and pieces and we can start to have a look at the wings !
What kind of laser do you use Fred. Do you have a pic of it.
Hi Alan,
This is a Black and Deker laser. This is a leveler, and "draw" a straight line.
I'll take a photo tonight. Cost me around 20 euros in Homebase :D
I never had to use it before, but in this case, this is really handy !
Hi Alan,
So, here is a photo of the laser thing :
(http://www.gliderireland.net/forum/images/uploads/Fred/laser.jpg)
And the progress on the fuselage :
(http://www.gliderireland.net/forum/images/uploads/Fred/fuselageentresillonsfini.jpg)
(http://www.gliderireland.net/forum/images/uploads/Fred/fuselageentresillonsfini2.jpg)
The webing is finished ! :D The fuselage is now really strong and light.
Next, I think I'm going to shape the nose and work on the Vtail :?:
Looks great Fred. I might get one of those lasers myself. It looks usefull.
Hi Fred,
Wow! Great build and a nice fuselage. You have left me behind already! Just about got all the bits of the B4 cut out now - just finished the ribs. Had problems with the outer tapered part of the wing as using the sandwich method the section turned out weird - the outermost rib blank is tiny. In the end, plotted and cut the ribs individually - at least the section is now consistent out to the tips. Will start on the fuselage assembly over the weekend. Any advice on how to plank a fuselage? Never done this before.
Hi Peter,
Good to start a new project ! :clap:
For ovoid fuselage like the Pilatus, the best way is to use 5 or 10mm wide balsa strips, and do the sheeting like a boat shell.
Easy and pretty much straight forward.
Other than that, you can use cardboard templates and plywood ( 0.4 or 0.6 I'd say at your scale :
(http://www.retroplane.net/forum/images/uploads/de_Schaetzen_Harold/PICT0059small_658.jpg)
(http://www.retroplane.net/forum/images/uploads/de_Schaetzen_Harold/PICT0061small_188.jpg)
Photos from Harold Ka2b :D :clap:
Back to the Ka3 now, with a bit of work on the huge V-Tail over the week end !
All the pieces
(http://www.retroplane.net/forum/images/uploads/loopingfred/empennagepieces_127.jpg)
And here we go ! The V-Tail assembly is a non event.. no difficulties at all here...
(http://www.retroplane.net/forum/images/uploads/loopingfred/empennagemontage1_517.jpg)
(http://www.retroplane.net/forum/images/uploads/loopingfred/empennagemontage2_107.jpg)
Ok, you can see the burn here... I think the cnc laser machine did a break here :lol:
(http://www.retroplane.net/forum/images/uploads/loopingfred/empennagemontage3_591.jpg)
(http://www.retroplane.net/forum/images/uploads/loopingfred/empennagemontage4_168.jpg)
And the result to motivate me !
Next are the LE, sheeting (with 2mm balsa) and the tail joiner made of carbone tubes (7mm ext. and 5 mm int.) and glued with epoxy
Same here, a non event...
(http://www.retroplane.net/forum/images/uploads/loopingfred/empennagemontage5_455.jpg)
(http://www.retroplane.net/forum/images/uploads/loopingfred/empennagemontage6_118.jpg)
Et voila ! the hinges are Robart type. the moving tail LE is sanded in 1/2 circle.
(http://www.retroplane.net/forum/images/uploads/loopingfred/empennagemontage7_149.jpg)
Next ?... back to the fuselage, with the nose cone, and i'll start to have a look at the cockpit interior... :?:
Non-events? I would be proud enough of that work if I was you to regard it as quite an Event!
:D
Ah well, no glory, it's just a big giant interresting puzzle ! :P
I had a look at the wings yesterday... Going to be big ! :D
Not a lot done over the week end...
But a bit of work on the wings.
So, 1/2 wing is almost completed, just the sheeting need to be done.
Photos of the early stages :
(http://www.gliderireland.net/forum/images/uploads/Fred/ailes1.jpg)
As I said, big puzzle ! The spar is made of Pine wood...
(http://www.gliderireland.net/forum/images/uploads/Fred/ailes2.jpg)
And then, the top spar :
(http://www.gliderireland.net/forum/images/uploads/Fred/ailes4.jpg)
For the ailerons, a balsa pieces is interlocking with the ribs.
(http://www.gliderireland.net/forum/images/uploads/Fred/ailes3.jpg)
Easy !
Well, I'll take more photos tonight, but the wing tip is done, so as the Leading edge (balsa 10mm + 5mm) and waiting for the wing joiner to come in to complete the sheeting.
I'll start the second 1/2 wing tonight ! :D
I love the lighting holes, almost like the real thing.
Keep it real man, keep it real !
:lol: :P
More work done yesterday !
The wing tips are done. the upper spar has been cutted to stick to the last 2 ribs. The gap will be filled with epoxy. The 2 triangles at the end are for the tip reinforcement... I'm a bit affraid that will bend during the covering (I will use Diacov from Diatex...Really strong !)
(http://www.gliderireland.net/forum/images/uploads/Fred/saumon.jpg)
And the cockpit frame is on the way.... slowly but surely ! You can see everything, so, that need to be detailled ! The nose cone is not glued yet.. I have to make a tow release mechanism first....
(http://www.gliderireland.net/forum/images/uploads/Fred/cockpit.jpg)
Well, the second 1/2 wing is already on the workbench.. I can't wait to put the wings together on the fuselage to see the beast !
Well... Moving on ! Yesterday evening was the first real assembly of the beast !
Well.. That is huge ! lots of volume... Can't wait to see that thing in the sky !
(http://www.gliderireland.net/forum/images/uploads/Fred/premontage.jpg)
(http://www.gliderireland.net/forum/images/uploads/Fred/premontage1.jpg)
Left to do : Wing sheeting, fuselage nose cone, install the radio, airbrakes, ailerons, covering !
Getting there !
:clap: :clap: :clap: :D :D Sweet I can't wait to see it fly to.
It's a beast all right! Nice work!
Excellent job Fred
I want a laser cutter!
Paul
Hi Paul,
Me too !!! :P :P
Sick since a few days... Haven't done much in the Ka-3... Garage is too cold !
Done the ailerons and prepared some bits for the week end.
My plan is to give it a good push over the week end.. Almost done ! :D
Bon courage
Merci Paul ! :D
Well, after a week off the garage (Flu.. :( ) Time to go back to the good old balsa sheets and start to do some work on the Ka3 !
So, here we go :
(http://www.gliderireland.net/forum/images/uploads/Fred/coffrageaile.jpg)
The wing sheeting is made from 2mm balsa. No real troubles here ! A balsa striper is used to make the 10mm wide strips for the ribs.
Good to be back ! :D
Looking very nice Mr Marie. Keep up the good work!
:D Thank you sir !
All the sheeting should be done by sunday... I hate doing that ! :!:
Next week, hopefully, covering and so on !
Almost there !
Looks nice and strong.
Nice job, best of look for rectroplane :clap: .
Thanks John ! :D
But I haven't done much on it for the past 2 weeks :oops: :oops: :cry:
Back to the workshop this week end ! :D
Well, after a looonnnggg break, it's time to go back to work !
This time, with the canopy frame.
The frame is made of 4mm diameter brass tube. Everything is solded using good quality solder.
The wood is protected with aluminium fold, and everything is solded in place. That will allow a perfect fit of the fram to the fuselage.
(http://www.gliderireland.net/forum/images/uploads/Fred/cockpit1.jpg)
(http://www.gliderireland.net/forum/images/uploads/Fred/cockpit2.jpg)
(http://www.gliderireland.net/forum/images/uploads/Fred/cockpit3.jpg)
Et voila !
(http://www.gliderireland.net/forum/images/uploads/Fred/cockpit4.jpg)
Looking good. Just some finishing touches to be made, and clean the frame.
(http://www.gliderireland.net/forum/images/uploads/Fred/cockpit5.jpg)
Tight fit on the fuselage. Looking good. all that, for a little 2hours of work !
I also have glued the V-Tail mounting/Support to the fuselage (no photos) and I'm shaping the nose cone.
Fuselage almost ready for covering ! :D
Looking good Fred!
Really getting there now :clap:
Very very nice Fred. Looking forward to see it grace the sky. :)
Thanks Anthony ! Me too !! :D
A step closer now !
So, after a long break, this week end was Ka3 time !
The fuselage is now finished, and need to be covered.
Some detailing has been done and need to be completed (a few details like the harness, control yoke etc etc)
(http://www.gliderireland.net/forum/images/uploads/Fred/vuecockpit.JPG)
(http://www.gliderireland.net/forum/images/uploads/Fred/vuepanel.JPG)
The paint is a spray "stone effect" from the local DIY shop. Great effect, and hide all the defects ! :oops:
The struts support on the fuselage were also glued. Made from 1.5mm aluminium. I also made some guides for the pushrods... The servos are in the cockpit, and it's a bit of a long way to get to the V-Tail !
And here is the beast, ready for covering (after the building jig is removed ! Very handy to have this to work on the fuselage...)
(http://www.gliderireland.net/forum/images/uploads/Fred/fuselage.JPG)
Next, the wings !
Servos, wirering and covering... Getting there !
Looks great Fred :D :D . I wish I had the time to keep working at my K8. Can't wait to see it fly.
Will ya put a suit of clothes on that thing for god sake! Looking great Fred!
:lol: :lol: Well, I obey ! :mrgreen:
So, another step closer to the maiden flight ! And one thing I hate to do is now done ! Covering a fuselage like this is always a big pain !
Well, 4 hours of work to get there !
(http://www.gliderireland.net/forum/images/uploads/Fred/entoilage1.JPG)
See the technicality of the thing ! :P Ok, well, it's a bit cold in the garage...Well, that's my excuse... :wink:
So, 4 hours on, and here it is !
(http://www.gliderireland.net/forum/images/uploads/Fred/entoilage2.JPG)
(http://www.gliderireland.net/forum/images/uploads/Fred/entoilage3.JPG)
Look like a fuselage now ! Still very light ! I just have to add the batteries, but the final weight is there... :D
Next, the wings wirering for the servos...
Fred, what is that material you use for covering?
Chris
Yes I would like to know that to.
Hi guys,
This is "DIACOV" from Diatex (the stuff used for the real ones).
Unfortunately, we learned last week that will not be produced anymore :cry: :!:
If you find a stock, buy it quick (and let me know where!) ! :D
Well, nothing really to be reported... Just the lower wing sheeting to be completed before the final covering...
Did the canopy :
(http://www.gliderireland.net/forum/images/uploads/Fred/verriere.JPG)
:wink: :wink:
Ready for covering ! :D
All servos are up and running !
I'll cover the wings this week, ready to go this week end ! (Well, hopefully ! :wink: )
Sorry for the dodgey photo, worst weather we had so far, can't take a shot outside ! :!:
(http://www.gliderireland.net/forum/images/uploads/Fred/montage.JPG)
And lots of paint after that ! :!:
Looks great Fred :D :D :What are you going to use to paint it? Dulux Vinal Mat or something?
Thanks Alan :D
I bought a can of Crown pure gloss white...
Tested on the V-Tail... :!: :!: Bad using a brush ! (waves on the paint... Too much surface to be painted..)
I'll go to homebase tomorrow, I'll check on a spray system... I let you know after I tested it, but can be a good airbrush system for cheap ! :D
I guess the first flight will be done without the paint job being completed...
Looks fantastic Fred - and huge! Really looking forward to seeing this one take to the air.
Hi Guys,
Well, that's quiet !
Here are a few photos taken about 2 weeks ago, before the covering is done !
(http://www.gliderireland.net/forum/images/uploads/Fred/ka3big1.JPG)
(http://www.gliderireland.net/forum/images/uploads/Fred/ka3big2.JPG)
The Ka3 is now ready for the maiden flight (well, still need to find around 1.5kg of lead !), so we'll see this week-end or the next one for the first flight, weather permitting of course !
I'll take more photos as soon as I can setup the beast outside !
Look beautiful Fred :clap: :clap: . It's a nice size to. What colour are you going to paint it, not red again :P .
I'm sooooo tempted! :D
Chris
Thanks guys ! :D
Come on Chris, come to the dark side of the force ! :P :mrgreen:
By the way, Maiden flight might be on monday, North slope of Mt Leinster !
I'll let you know if you want to come and have some flying !
:-# :D !!
:mrgreen: :P
So, it looks like north-east Monday. What is Mt Leinster like in that direction?
Looking at my OSI Map it looks like part of the north slope at Mt Leinster points in a slighty north eastrly direction, the part that is up the pathway from the carpark.
I might try and make it. I'd love to fly that north slope, Oh and see Fred's Ka3 fly to of course :D :D :D .
Hey Fred. It looks like the wind will be coming from a more eastrly direction on Monday. Will Mt Lenister be flyable?
Hi Alan,
Yep, Mt Leinster is a 360 degrees slope ! :D
Remember the last time you flew at Mt Leinster ? well, on your back, this is East. The slope at the car park is North East to give you an idea.
Hi Fred,
New glider is very nice. Hopefully there will be flying tomorrow at Mt Leinster. Will be there to see it flying for first time.
cheers
David
The wind is turning more east alright. Thats a shame. North-east is really good at Mt Leinster. My favorite slope. I have never flown east at Mt Leinster. I'm not sure if or how well it will work!! There is a small ridge but don't know how it flies!. If the wind is a bit north we are laughin'. Will have to wait and see tomorrow
Good morning everyone !
Well, today, I'm a happy man !
The Ka3 have made his maiden voyage yesterday afternoon !!
All went more than OK, no trims touched, flew straight from the launch !
Just a few elevator up after a little while, certainly due to my CG too much forward.
Nothing to say really, that is a big trainer, really easy to fly ! A bit too light (we reckon between 6 - 7 kg...).
Sorry, no photos of the flight, nor as videos yet (my camcorder died !! But hopefully soon !
(http://www.gliderireland.net/forum/images/uploads/Fred/pente.JPG)
(http://www.gliderireland.net/forum/images/uploads/Fred/pente1.JPG)
Excellent plane and excellent flight!
If video is what is needed that can be provided! ;)
Thanks a mill Fernando ! :D
If you have a video you can give to me, go ahead !! :D :D
Just dying to see it ! :D
If you want i can dump all the videos i've made and put them on a DVD for you. So you can edit and mix them around how in the way you want.
But in the mean time i'll try tonight to edit and put something here! :)
Thanks a million Fernando ! :clap: :D :D
Ok,
Yesterday the software didn't want to help and i didn't do what i wanted! :(
BUT i managed to use the Windows Movie Maker and at least show something here!
I promise i'll do another one with MUCH better quality! :)
http://www.youtube.com/watch?v=9ZTF2Yf7mDQ
.Nando
Remind me the landing ! :P Won't stop !!
More ! =P~ =P~ =P~ :D
Painting on the way !
Happy with the roller technic :D .. Much less with the paint !! :evil: :!: :!:
Used Crown paint, the cheapest I can find for all my other gliders, and each time, I had a perfect finish !
For this one, I bought Crown paint still, but at least 3 or 4 time the price I used to pay... Thinking this glider worth it...
Worst paint ever !!
My advice (a bit too late for me...)..Stick to the cheapest paint you can find ! They work perfect !
(http://www.gliderireland.net/forum/images/uploads/Fred/aile1.JPG)
Ah well.. 1 meter away should be invisible... :roll:
...Ah well.. 1 meter away should be invisible... :roll:
Fred, think about the fact that our gliders are just to perfect comparing to the big ones, so some faults are just right. And the big advantage, if somebody is making any remark about your finsh, just tell him that the big one was the same, its just scale :D
Stephan
:lol:
Well, that is true !
Seeing the state of some full size glider, sometimes, well, most of the time, ours are really neet compare to the ones we try to reproduce !
I'll give another go with another layer of paint, and we'll see tomorrow... Otherwise, as Vincent said, I'll buy another type of paint and give it a go.
Hi guys,
Thanks to today's weather and Anthony, here are tonight's photos of the Ka3 !
99.9% done, the rest is just cosmetic (pitot tube on the nose and gluing the pilt's seat with the harness).
Looks good.. 2 meters away ! :oops: still not happy with the paint job ! :!: :!:
(http://www.gliderireland.net/forum/images/uploads/Fred/jardin1.JPG)
(http://www.gliderireland.net/forum/images/uploads/Fred/jardin2.JPG)
Can't wait for the next flying session ! :D
Great job Fred, hope your Ka3 gets a pilot :?: it would be a pity if not :cry:
Stephan
=P~ =P~ =P~ =P~ =P~ =P~ . That looks sweet, well at least from 2 meters away :P :wink: . Are those registration numbers vynal stickers or were they painted on with vynal maskes?
Thanks Stephan :D I have a pilot for it, that was just a quick setup in the garden (no time to put the struts too!)
Alan, there is both ! I had a bit of a missap when painting the registration number...
So Anthony cutted me stickers (I guess this is vinyl, really thin anyway !) for the other half ! :oops: but you can't notice the difference, except that one side if you look carefully, it's less clean ! :!:
Hey Fred.
I've been quietly following your progress over the last few weeks. Nice woodwork on the Ka3. :) The Mustang reminds me of a similar model I had years ago from the US. It was a nice flier but it needed a good blow. Ralph had a Komet by the same crowd if I recall.
The iminent first flight of a 4m Fox in Cork got me to to thinking about my Blanik last night. It's been in the box since it arrived with the postman six months ago.
Stephan's comment about a pilot got me thinking about one for the Blanik. Do you have a source of full body pilots, maybe from France ? Mr Axels creations are the bees knees, but too expensive for my tastes. I might check the Retroplane site for links.
Keep up the good work ....... and don't forget the CMAC glide-in on the 20th .....
Kevin
Hi Kevin!
Nice to be able to "talk" to you via this medium!
I simply adore Foxes, and have been trying to make up my mind about which one to get for a long while, my problem being I have never seen a decent size scale one if the flesh! It seems to me that they are BIG planes, if you just go by wingspan alone, due to the relatively big fuses. Those fat fuses could also make launching (particularly on your own) tricky. It would be great if you could post some info about yours, and pictures would be even greater :D Maybe even start a tiny little thread of your own? :roll:
I really enjoyed last years CMAC glide-in, wild horses and wagon ropes won't keep me away this year :D . Whilst I'm praying for SW (so we can fly at that amazing spot at the Old Head of Kinsale), do you have venues close by where you can fly if it isnt blowing SW?
Cheers
Chris
Hi Kevin,
Thanks for the KA3 ! :D
I have a few sources for scale full body pilots in France and in the US.
I can't remember the website names, but I'll have a look and let you know.
I actually have a 1/3 and 1/4 pilots from the US. They are looking good, but are in semi-hard latex. I can bring them in the glide-in for you to have a look. I still have to figure out what to do with them, and if we can modify them at some extend for us... :?:
But they are way cheaper than the Axel ones !
Or if you are a few looking for pilots, why not make a mold to make them ?
I haven't translated it yet, but here is my technique to make them... Photos are enough to understand !
They are made with PU, very light ! That's also really easy to do !
You also have links in the thread for sourcing pilots.
http://www.retroplane.net/forum/viewtopic.php?t=775
Enjoy ! :D And let me know if you need something to be translated !
About the Fox, why not doing a thread here ? We really never hear from you guys ! :wink:
Chris, I have a Fox, but small one (2.20mtrs).. I don't fly it anymore :?: :wink:
Here is a new video of the 1/3 scale Ka3. Still from the first flight :D
Enjoy !
http://www.gliderireland.net/images/videos/bigka3.wmv
18Mo for 3.30mins...
Nice landscape, realy beautiful and nice flight concratulation ones more Fred
Stephan
I agree. That was a nice flight. Especially the landing :D :D :wink:
Yes - good to relive that one! Well done again Fred. It's going to look even better in the air with its new colour scheme.
Thanks a million guys for the warm comments ! :oops: :oops:
Hopefully, next week end, some of you will see the beast flying ! Finger crossed for a good slope and good weather ! :D
Hi Kevin!
Cheers
Chris
Even a reply to tell me to get st****d would be nice :!: :!:
Alright, Following my "hard landing" (who said crash ??? :P :P .. These things happen, even to the best ! :P ) it's time to go back to the workshop and check the damages...
Well, with the covering, that looks much worse that is actually is !
I removed the covering, and here is what I've found :
(http://www.retroplane.net/forum/images/uploads/loopingfred/ka3-1_781.jpg)
(http://www.retroplane.net/forum/images/uploads/loopingfred/ka3-2_167.jpg)
Not bad ! :D
Thanks God this thing is made out of wood ! :P
So, the things to do is to first straight all the pieces together using CA glue.
Then, glue Sq. pieces of hardwood under with epoxy.
(http://www.retroplane.net/forum/images/uploads/loopingfred/ka3-3_201.jpg)
And after 40 minutes work :D :
(http://www.retroplane.net/forum/images/uploads/loopingfred/ka3-4_176.jpg)
All done ! Just need to recover the front panels now ! Not really looking forward to do it :!:
Left to do, is one of the VTail hinges.. All dead, need all to be replaced... But that's another story ! :wink:
So,........ that's how the "pro's" repair plane's is it? :clap:
All very interesting. You should publish a series of 'How to Workshops' Fred.
I want to see how you re-cover it!
Keep up the good work, and when will we see her flying again?
Thanks Keith :oops:
Well, not sure about the pro thing though :?: :wink:
I did a few technical article on the website, but they are the less watched compare to all the other pages.. Not sure there is still an interrest in this kind of things on these RTF days :-s
Anyway, the good thing is that the glider is made of wood.. And I built it, so I know where all the small pieces are going at the end, that's help ! :lol: :P
The main thing to watch is to be carefull not to twist the fuselage while rebuilding, other than that, all easy to fix.
For the covering, well, I'm not the best guy for that ! I'm absolutely rubbish in covering, and the Diacov is not an easy covering material to use :!: But I'll try ! The best will be to recover the entire fuselage, but I have no time, leaving for France next Week end for Retroplane ! :D
That's why now, I'll only do fully wooden gliders ! :P
Stay tuned ! :D
Hey Fred,
Ten weeks latter and I remember to post a reply. I need to visit the forum more often. I'll take a look latter at the Retroplane link for pilots, so thanks for the steer. I'm not putting much time into the fleet these days for various reasons so I won't be needing a pilot for a while yet.
I've watched the Ka3s maden flight on the thread. I know I lean towards glass ships, but there is certainly something romantic (?) about the old wooden vintage machines.
BTW, I think the Fox has flown. It belongs to Ralph, not myself. I have an L213 on the bench similar to Joe's. She's the one looking for a pilot !
Happy landings ....... :lol:
Kevin
PS The MACI video was great. Keep posting them for us armchair fliers.....!
Hi Kevin,
No worries !
Alright, so, following the repairs of the Ka3, here is a mini how to :D
How to repair Robart's type hinges !
All here :
http://www.gliderireland.net/robartrepair.htm
Enjoy ! :wink:
All done now !
Here is the (almost) finished result...
(http://www.gliderireland.net/forum/images/uploads/Fred/ka3entoilagerepair1.jpg)
(http://www.gliderireland.net/forum/images/uploads/Fred/ka3entoilagerepair2.jpg)
Still a few wrinkles, but you can't really do it much better...
The best solution at this stage would have been to re-cover the entire fuselage... But no time, this is a big piece to do, and Retroplane is near us !
But finally, after a layer of paint...
(http://www.gliderireland.net/forum/images/uploads/Fred/ka3entoilagerepair3.jpg)
The result is quiet good !
Can't see a thing 1 mtr away...
Second layer is coming soon, and that will be the final touch !
Gliser ready to go again ! :D
Fred, if you ever look at the typical club glider, it's all seams and patches and mismatched panels of covering anyhow. (Least the ASK13s and ASK7 I was around were!) So you're still sclae... :)
Heyyy Carl ! Long time no see !! :D
Yes, that is true ! Saw a lot of vintage gliders, and most of ours scale mpdels are much better looking than the real ones !
And this is not a bad excuse for me to be very scale with my models !! :P :P
Here's the 1:3 movie from YouTube
[youtube]http://www.youtube.com/v/xVs22kaewBE[/youtube]
From time to time, I receive photos and build logs for gliders built from my plans or our kits...
Here are 2 photos of what is so far, the most beautiful 1/3 Ka3 I know !
First flight was done 2 days ago, all went well !
Built from the Kit, with wings plywood sheeted, and all the scale details ! (shame to have to cover all that at the end ! :( )
Congratulations to the builder / pilot ! :clap:
(http://www.gliderireland.net/forum/images/uploads/Fred/Ka3%2BErstflug%2B001.jpg)
(http://www.gliderireland.net/forum/images/uploads/Fred/Ka3%2BErstflug%2B006.jpg)
Wow that looks great. That picture really shows how big it is.
trop genial j'ai hate...
Beautiful! :) Really should finish my 1/4 scale version :cry: :(
de construire
Fred,
is there any dihedral in the 1/3 Ka3?
Cheers
Hi Ralph,
Yes, there is (as you can see on the photos on top)
2 degrees on top of my head
hi ralph, the 1/4 scale version has holes in the 1st few ribs out from the root for the tubes that take the joiner rod. this sets the dihedral angle. i assume the 1/3 version is the same or "doth i assume too much?"
“Doth I assume too much” !!!…
How very Shakespearian of you Gerry, :shock: ………me thinks.
I had no idea you were a man of culture & breading like myself :P
Don't sit in any warm places kieth if your a man full of "culture and breading". the yeast in you will make you swell up a POP like a balloon.. Could get messy ya know.
LOL :lol:
D.
now look what you've done keith!! even dave the baker is watching your spelling! i thought we were going to stick to matters aero?
ps very impressed with your explanation of props to john on the dh 2. i learned loads myself. well done!
Oh!... that made me laugh Dave, thanks for that. :clap: (In fact I’m still chuckling to myself!) :lol:
Yes Ger you are right. I should have stuck to matters aero. I guess old habbits die hard!! :roll:
here's main, have served me many nice flights
(http://www.gliderireland.net/forum/images/uploads/conny/ka3.jpg)
You have it for a few years now? :D Still flying ?
it has provided many hours of pleasant flight, but have not tried hang whit it. must try this spring ... :D
progress.......(http://www.gliderireland.net/forum/images/uploads/rogallo/389227_3543160212326_1242844780_n.jpg). Installing wing servos and doing the associated wiring :(
Looking good though, if I do say so myself.
nice one ralph, distinctive colour scheme to say the least. will it be ready for tountinna on the 16th?
Hi Ger,
I don't know when it will be finnished, under a lot of pressure here in work and must find some tome to just Relax!
I hope to Maiden it at your flyin, without its reg number methinks!
We will see,
Tell Dave to have his buns warmed up!
God, missed that one! :oops:
Looking very good Ralph! :clap: :clap:
And a nice colour scheme :D
Fred,
are you traveling to Gerrys event in 2 weeks time? I have food and tape for you!
Can I ring you at work? Can you pm me a work number?
And sent :D
good job ralph :clap:
Merci beau coup
Lovely job Ralph, I hope you have many many good flights !
After a long pause work has started frantically again.......
Canopy frame painted and still wondering how to attach it to the fuse.
(http://www.gliderireland.net/forum/images/uploads/rogallo/ka3.jpg)
Very good Ralph! :clap: :clap:
Might be too late in your case because of the covering, but here is one idea :
(http://www.gliderireland.net/forum/images/uploads/Fred/b16dhdf.jpg)
(http://www.gliderireland.net/forum/images/uploads/Fred/b24dfhghs.jpg)
(http://www.gliderireland.net/forum/images/uploads/Fred/b25fdhdh.jpg)
With an hinge on top to articulate the canopy up.
In my case... Blenderm! :D
I'll do something like above for my next one...
Thanks Fred,
but blenderm now there is a good idea, and to think I have a few boxes of it for you here in Cork courtesy of Ronan :)
Cheers
:twisted: :twisted:
:mrgreen: :mrgreen:
Help, I am looking for a pilot for my Ka3 any suggestions where I might find one?
Cheers
Depends how muc h money you want to spend Ralph. AH Designs in Wales are cheap. Axels in Germany are expensive but exquisite.
You pays your money & makes your choice! :?:
AH takes forever though......Need it for the 10 sept at latest
hi ralph, have you thought of a.h. designs, pete's pilots, i think another one is alex pilots.
i picked up some kids' toys which were water squirter guns shaped like heads.
bodies, arms and legs from foam, pullovers from sleeves of my kids pullovers and jeans from old jeans et voilá, pilots to grace any cockpit.
Borrow one?
Is that an offer?
sorry Ralph only have a 1/4 scale AH designs job
Yes they look like small kids in the cockpit, cheers anyway
i'd ring ah designs and tell them you want it asap
i had ordered one for the K8 and as ralph say's it was takin for ages i rang them up and i had it within a couple of days
worth a try :D
Hi Ralph.
I got the pilot for my K8 from Premier Pilots, www.premierpilots.net/ . They are not cheap, but they are cheaper than axil pilots I think.
Oops sorry :oops: :oops: . Just relised your K3 is 1/3 scale and Premier Pilots only do 1/4 scale at the moment.
try retroplane website, search for 1/3 scale ka3 by johannes vannahme, page 11, dated 19/12/2007. pilot from denupiloten.de. i checked it out, found nothing. fred might have an e-mail contact with johannes for more info.
night, night, gb
Hi Ralph,
Contact for Johannes in your inbox :D
As for pilots, I have ordered some in a few different places :
www.premierpilots.net/ (but only 1/4. Good quality stuff for a reasonnable price)
http://www.iflytailies.com/store/pilots/1-3-scale-pilots/ (never tried)
http://www.Perfect-Pilots.com
http://www.thepilotpeople.co.uk/
And lots more!
I bought also some that were in latex, to be painted from the US. Bought 2, in 1/4 and 1/3 scale, but they are no good for us unfortunately, unless you do a bit of cutting / grinding work as they are too much in a seated position if you se what I mean.
Can't remember the link, I'll try to find it.
Also, if you have a bit of time, very easy to do your own one!
You can buy head, hands / shoes and also full body pilots here : http://silencemodel.fr/category.php?id_category=75 (this is Pascal's shop)
Hope this helps,
Thanks everyone, will start looking in the morn. I will keep you all updated,
Seen these Ralph:
http://www.ytinternational.co.uk/tailored_pilots/tailored_third.html
Bit pricey (£180 for 1/3 scale) but very well made and can be animated!
