Quadcopters / Drones / Helicopters / Rotary wings stuff => Electrics => Topic started by: Happy Days on September 14, 2008, 14:00:18 PM
Title: Nano-Phosphate For Ever
Post by: Happy Days on September 14, 2008, 14:00:18 PM
I've just finished building and testing some multi-named battery packs. You might have seen them referred to as any of the following: A123 Batteries. (After the name of the company that developed them, A123 Racing.) Or M1 cells, or Lithium-Ferrite batteries. (Li-Fe) or Nano-Phosphate batteries.
But a Rose by any other name is still a Rose.
The main problem with these batteries as far as I've experienced is two fold.
1/ Their weight per milliamp is slightly higher than that of Li-Po's
2/ These cells only come in one size: 2.3mAh at 3.3v
Each cell is 65mm high and aprox 26mm dia. (About the same dia as a 2Euro coin.)
I should think these facts alone would make them of little interest to power gliders, but to electric power flyers like me they're FANTASTIC. (In my opinion)
Why? I hear you ask. :?:
Well, just look at the plus side:
A/ These cells pose no fire risk, so you can recharge them inside the model if you want to.
B/ They only need balancing every 10 to 20 cycles.
C/They are no more expensive than Li-Po's
D/Discharge rates of 30C. - Phew!
E/ They last for between 1K and 2K charge/discharge cycles. Yes, you read that right, up to 2000 cycles!
F/ And here comes the icing on the cake; they can be safely recharged at 4C i.e. Fully recharged in 15 minutes!
These batteries have been used in the cordless power tool industry for some years now. In fact the cheapest way to buy them is to buy a cordless power pack that uses Nano-phosphate batteries and remove the cells from the pack, as I did.
This has the added advantage of getting cells that have a tin plated solder tag spot welded to each cell. (I should point out that these cells have an aluminium casing,.....very difficult to solder to.)
Guys, this has been a very long post and I'm not used to all this typing :(  so I'll stop now. If anyone wants any more specific details, just ask.
