Planes > Indoor
Building and flying P-25 indoor (the elastic model airplane)
<< < (2/4) > >>
alle:
Cutting the remains of the wing, the elevator and rudder
[/URL][/img]
[/URL][/img]
[/URL][/img
alle:
Making the dihedral of the wings (which is polyhedron) and the rudders.
 I always start by the middle of the wing, I'll even break some fibers warping step ca ai ai and let dry again ca.
 The rudders are at right angles as it is harder to break down some fiber, so sometimes I have to for a few props, this case did.
[/URL][/img]
[/URL][/img]
[/URL][/img]
alle:
Angle of attack of the wing.
 I leave almost equal use 1 or 2 mm difference in the leading edge of the board to escape, usually do well Fortinho media wing, broke the previous always there.
 (also is leaving the adjustable angle of attack there are several ways, but is for another time)
[/URL][/img]
alle:
Propeller Shaft
 Always make the helices fixed.
 I hook shaft, while the bearing, put the bead and helice, drop and roll ca a little line and ca again, that the maximum of attention to helice should form an angle of 90 degrees with the shaft.
[/URL][/img]
[/URL][/img]
alle:
Prop
 materials
 piece of balsa 1 / 16 or 3 / 32 and sanded
 toothpick
 Mark the center of the toothpick and stick with the drill or own wire if wire has to have patience.
[/URL][/img]
[/URL][/img]
[/URL][/img]
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
