Author Topic: Quark 2M - Back to cutting innocent trees!  (Read 838413 times)
« Reply #120 on: November 10, 2011, 20:42:10 PM »
:oops:
Wow, that good, really?
Ok, I must remove the fingers and finish to cover mine to give it a go! (So do you Mr B!  :P )
Thanks again Mr Boyd for the comments, especially coming from a pilot of your class!  :clap:  :clap:
Was concerned a bit for the rudder, this is one of the hardest part to get right in size / effectiveness and must work without adding to much induced effects.
« Reply #121 on: November 10, 2011, 20:42:54 PM »
Fred just checked the CofG position:
75mm from the leading edge on the fuslage, or at the front edge of the front wing joiner hole pre drilled into the side of the fuselage.
Throws:
Elevator, as shown on the plan cut out (all flying tail) I used 60% expro rate on the elevator also.
Ailerons, 30mm again I used alot of expo 60%
Rudder as much as possible 40mm each way with 60% expro
« Reply #122 on: November 10, 2011, 20:46:26 PM »
Thanks JP, I'll add your throws on the plan (I'm bad for that, I always put the maximum everywhere!  :oops: )
« Reply #123 on: November 10, 2011, 20:56:09 PM »
Fred with those big ailerons you could use larger throws if you wanted to, a 30mm is a good starting point. however with the expro rates you can have the best of both worlds, a smooth flying fast glider one second, and a highly aerobatic plane the next, with full control throws used
« Reply #124 on: November 10, 2011, 20:58:05 PM »
True!
And the ailerons are... well, big  :mrgreen:
« Reply #125 on: November 10, 2011, 21:01:24 PM »
[youtube]http://www.youtube.com/v/Q1RsOcMB7jQ[/youtube]
« Reply #126 on: November 10, 2011, 21:06:51 PM »
Very good Richard, thanks for the video!  :clap:
Looks like the glider have a correct speed range, and the rolls looks very sharp in the stops.
I like the hability to turn a roll with almost no speed  :clap:
Well, that is looking really good for a first flight!  :clap:  :clap:
And thanks for the flag  :lol:  :lol:
« Reply #127 on: November 10, 2011, 21:18:41 PM »
good video and good music :lol:
« Reply #128 on: November 10, 2011, 21:42:13 PM »
Hi Fred, I am happy the video gives you a small hint of how your Quark flys.
Next visit to the mountain I hope to get John to do the video footage.
This Quark is so sweet.
I never fly a borrowed glider hard as I have smashed other peoples planes in the past and felt really guilty  :(
This time the I feel the quark has so much to offer and I hope to surprise you  :wink:
Keith , the Quark is blender heaven  :clap:
I am clearing my bench tomorrow and starting to build the Quark kit I got from Fred yippee
« Reply #129 on: November 10, 2011, 22:20:13 PM »
Quote from: "Richard Boyd"
I want one!,……..no, I want a dozen!!!  :D
(BTW Richard, I’m still struggling with blenders. Sometimes I can do them, sometimes I can’t. :!: )
I must say I’ve rarely heard of a new model that caused such an uproar on a forum. So well done to designer, builder and pilots. :clap:  I’d be very interested to see how The Quark performs in the big winds of winter.
I’ve got quite a few projects coming up for the workshop so I won’t be getting a Quark this side of xmas,……. but in the New Year perhaps. :wink:
Well done Mr. Boyd for a rapid video production. I see you sneaked in a few aerial shots, you cleaver little chappie you! :clap:
« Reply #130 on: November 10, 2011, 22:28:34 PM »
I saw a corner of an F22 Raptor in that Video. Did you fly that too?
« Reply #131 on: November 10, 2011, 22:48:35 PM »
Hi Bill
Yes we throw the F22 off the slope, but hit a down draft which happens on the south slope, the F22 hit the ground  down the slope, and one of the control horns on the ailerons snapped off so no joy this time, I will replace the part and try again, this time off one of the other better slopes.
« Reply #132 on: November 10, 2011, 22:53:54 PM »
Ah well, at least it's still in one pice and you can try again
« Reply #133 on: November 10, 2011, 23:09:59 PM »
Congrats John on the new arrival so its a girl.
She looks beautiful. Fred when is kit coming out I think there would be plenty of interest what with Christmas and a 50th birthday approaching.
« Reply #134 on: November 11, 2011, 10:25:26 AM »
Good morning everyone,
Plans for the Quark2M are now available!  :D
The non tiled version won't fit in a A0 sheet, so that is a bit oversize!
Fuselage plan - 1410x800mm
http://www.gliderireland.net/files/quark/Quark2M-FuselagePLAN.pdf
Wings plan - 1110x800mm
http://www.gliderireland.net/files/quark/Quark2M-WingsPLAN.pdf
And tiled versions for A4 printers:
http://www.gliderireland.net/files/quark/Quark2MFuselage_tiled.pdf
http://www.gliderireland.net/files/quark/Quark2MWingsPlan_tiled.pdf
As for a kit, well, we'll see if there are enough requests, and I can launch a production.
Anyway, have fun!  :D  :D
