Author Topic: 1/4 scale Ka-3  (Read 107978 times)
1/4 scale Ka-3
« Reply #15 on: May 22, 2006, 07:59:44 AM »
So, the sheeting is the only thing left to do, not before gluing some blocks inside the elevator for the hinges :
And finally, gluing of the "real" LE and sanding :
Et voila !
Then, the elevator (mobile one.. don't know the name for that in English.. :o ). The building is like an Aileron, so, no big deal here.. :
You've got the idea... Only thing left here is to put the TE, made with 1.5mm liteply.
1/4 scale Ka-3
« Reply #16 on: May 22, 2006, 08:03:16 AM »
But before that, firt quick setup in the sitting room to confirm that i'm building a Ka3 :
Yep, I'm sure now, that's a Ka3 !  :p  :p
So, tonight : cutting of the plywood for the TE and start to build the mounting for the elevator on the fuselage.
1/4 scale Ka-3
« Reply #17 on: May 22, 2006, 12:42:54 PM »
guess they'd be called ruddervators :?:
it's a beautiful thing Fred,a beautiful thing :D
1/4 scale Ka-3
« Reply #18 on: May 22, 2006, 15:33:40 PM »
Thanks a mill Joe !
And for the name of those.. humm.., things, I go for V Tail ! Much more easier to pronounce !!  :D  :D
1/4 scale Ka-3
« Reply #19 on: May 23, 2006, 09:24:28 AM »
So, let continue with the V tail.
So, I'm on target and made the liteply TE and parts for the V-Tail :
So, tonight, I go back to the fuselage and start the nose cone and the cockpit frame.
1/4 scale Ka-3
« Reply #20 on: May 26, 2006, 07:57:30 AM »
So, here we go again !
This time, on the fuselage and the cockpit section.
First it's time to glue the bottom canopy frame :
Then, cut a balsa block to fit the nose. The only "difficult" part of the job here is to respect the sides of the fuselage on the balsa block during the sanding.
Before :
After :
1/4 scale Ka-3
« Reply #21 on: May 26, 2006, 08:02:22 AM »
Then, as usual, put the wings on the fuselage... Can be proud of the result now !  ;)
And just for the pleasure, I've cutted 2 tubes for the canopy frame to have an idea of the finished product.
Happy !
So tonight, the plan is to finish the canopy frame, and this week end, the wings.
See you on monday !
1/4 scale Ka-3
« Reply #22 on: May 29, 2006, 07:54:13 AM »
Hi There,
This week end were the days to design the V tail mounting system.  The trick here, is that I wanted to have the V tail removable in 2 pieces. The V tail is huge and if you really want to gain space, you need to have a 2 pieces tail.
So, finally, after 3 prototypes and a bit of brain cells, I've found a very simple solution to my problem.
4 pieces of wood, and 2 carbon tubes and that's it !
Then, plug both elevator/rudder :
Fit perfectly !
Happy !  :)
1/4 scale Ka-3
« Reply #23 on: May 29, 2006, 07:57:55 AM »
Ok, so, I'm happy with the results, and now, it's time to celebrate by doing the wing sheeting and others details !  :D
Happy ! Not a lot left to do now, and hopefully, I'll be able to start the covering this week.
1/4 scale Ka-3
« Reply #24 on: May 29, 2006, 10:59:56 AM »
Wow! you really do work fast Fred.really coming together now.looking good.the mount for the v-tail looks great.bet your glad to have that bit sorted out.any pics of the colour scheme your going for? the red one right?
1/4 scale Ka-3
« Reply #25 on: May 29, 2006, 18:29:49 PM »
Hi Joe,
Yep, you're right ! Pretty happy to have finish this part of the glider ! Big head hake.. But finally, at the end, something really easy, and only 4 pieces of wood ! :D
For the scheme, i'm going for the red and white. Really vintage colors !
So tonight, it's electronics time ! I've just received my servo wire ! So, I can finish the wings now !  :D   Yeepeee !
1/4 scale Ka-3
« Reply #26 on: June 06, 2006, 08:21:19 AM »
Well..
A bit late on schedule, but finally, the Ka3 is ready to cover !  :)
This week end was just a bit of work on the scale details on the cockpit :
Almost finish by now.
Then, it was time for a last look at the wooden structure before the covering start :
Hopefuuly, finished to cover during the week, and maiden is plan this week end, weather permitting !
1/4 scale Ka-3
« Reply #27 on: June 06, 2006, 17:53:07 PM »
looking good Fred!.i like the cockpit.the wing sheeting job is nice too.nice work.nearly there!
1/4 scale Ka-3
« Reply #28 on: June 06, 2006, 20:37:05 PM »
Thanks Joe !  :D
Nearly there ! Covering will be finish Thursday, that leave me friday to finalise the radio installation.
Looking good for the maiden this week end !   :D
1/4 scale Ka-3
« Reply #29 on: June 12, 2006, 08:34:49 AM »
Hi there,
Quick update on the KA3 with the covering :
And the painting of the fuselage, just to have an idea before starting the wings and elevator :
Nearly there !
