Author Topic: Pilatus B4 build  (Read 51371 times)
Pilatus B4 build
« on: January 02, 2008, 19:46:26 PM »
Not really a build tread - I work too slowly for that!  But a progress report on a Pilatus B4 build from an old Mike Trew plan.  As you can see from the photographs, the fuselage is coming on.  Half planked (that took a bit of time!) and currently I am working on the controls before planking the rest.  Made the tailplane last weekend - it is bolted on.  As I have changed the wing section I want to be able to alter the longitudinal dihedral as I suspect that on the plan is too high for the HQ25/12 section I am using.  So far so good - but anyone else building from this plan, watch out for F11 - this does not have the correct profile!
Anyway - best wishes to all for the New Year.  Scamper - I hope all this talk of DG1000s does not mean you have give up on your B4!!!
scamper
Pilatus B4 build
« Reply #1 on: January 02, 2008, 20:24:41 PM »
Looks very good.  :clap:  Hope to get going on mine again soon. I got the wood, piano wire joiner and airbrakes from Topmodel with the DG-1000. All i need now is the motivation. :lol:
I put F11 in and didnt notice until later that it was wrong. I had to glue another piece of ply to it to get it to the right profile.
Pilatus B4 build
« Reply #2 on: January 03, 2008, 07:40:24 AM »
Hi Peter, good to hear back from you  :D
The Pilatus is looking really good indeed  :clap:  :clap:
Pilatus B4 build
« Reply #3 on: January 03, 2008, 13:39:51 PM »
Nice work. Keep it up. :clap:  :clap:
cvanscho
Pilatus B4 build
« Reply #4 on: January 03, 2008, 17:42:04 PM »
Nice job, Peter!
Pilatus B4 build
« Reply #5 on: March 31, 2008, 21:06:08 PM »
Right - seems with this poor weather quite a few of us are busy building.  Here then is an update on progress with the B4.  Fuselage is mostly planked now and servos/controls installed.  It looks much better now I have added a nose block!  Currently working on the first of the wings - fully sheeted structure so trying to get the innards sorted before adding the top sheeting.  The idea is to build both wing panels minus the top sheeting so that I can sort out the joiners/dihedral/alignment to fuselage. Constructing a canopy is looming so any advice much appreciated - not done this before. Also  would like to make a hinged metal (aluminium?)frame for the canopy perspex - how should I go about this?
Stephan
Pilatus B4 build
« Reply #6 on: April 01, 2008, 07:13:04 AM »
Hi Peter
for the first time I see a B4 in an all wooden approach realy great  :clap: That changes from this fiber and foam stuff.
Stephan
Pilatus B4 build
« Reply #7 on: April 01, 2008, 15:38:27 PM »
Hi Peter,
Like Stephan, totally agree !
Really nice job, and so rare to see a Pilatus built in wood !  :clap:  :clap:
Pilatus B4 build
« Reply #8 on: April 01, 2008, 15:52:18 PM »
I agree also  :clap:  :clap: . And when it's fully built you won't even know it was built from wood.
Pilatus B4 build
« Reply #9 on: April 01, 2008, 20:45:51 PM »
Thanks guys. Yep it is amazing what you can do with wood - time consuming but satisfying! I'm quite impressed with what complex shapes and curves you can create with a bit of effort.
Pilatus B4 build
« Reply #10 on: April 01, 2008, 21:06:28 PM »
Well, I can't disagree with that !  :mrgreen:
Sorry I haven't answered your question about the canopy...
Well, with balsa locks, you can make a plug and then vaccum form the canopy (http://www.gliderireland.net/vaccumforming.htm) but manually is also fine (use a 2 liter coke bittle...)
I have the vaccum box if you want to borrow it ! (and clear plastic too...)
For the frame, I will do it in brass tubes and soldered. Easy to form in shape, easy to solder too (see the frame for the 1/3 scale Ka3..)
Pilatus B4 build
« Reply #11 on: August 29, 2008, 17:08:41 PM »
An update on progress - or a couple of photos anyway! Actually beginning to look like a glider.
Pilatus B4 build
« Reply #12 on: August 29, 2008, 17:13:56 PM »
Peter. I dont know if its a problem with my computer but I can't see the pictures  :( .
Pilatus B4 build
« Reply #13 on: August 29, 2008, 17:15:51 PM »
Nope - I cannot see them either .  I'll try again.
Pilatus B4 build
« Reply #14 on: August 29, 2008, 18:03:59 PM »
I can see them now. Looks sweet  :D  :D  :D . Keep up the good work.
Makes me want to make a glass glider out of wood to.
