Author Topic: new arrival - skypup 1976  (Read 16597 times)
DennisZ
« on: May 02, 2013, 19:00:19 PM »
« Reply #1 on: May 02, 2013, 19:35:31 PM »
Hi there Dennis, :D  long time no speak (or see.)
So what’s the story behind this Skypup? :?:
DennisZ
« Reply #2 on: May 02, 2013, 21:15:22 PM »
I got it as a kit
Took some 18 months to complete
Flew couple weeks ago at phoenix park. Just barely made it - only able to stay afloat at full throttle.
Upgraded now to 4 cell and 3 blade setup - should give twice as much power (in theory). Have not tried again yet.
« Reply #3 on: May 02, 2013, 21:53:04 PM »
Good man Dennis! I wondered what you’d been up to this past year or so. Going into powered flight er?
 :D
It looks a sweet little model. With the flat bottomed wing and loads of dihedral it should be a very stable four channel flyer.
 8)
The extra celled battery should add quite a few extra rpms. (provided the motor and esc can take it of course.)It looks like that is about a 1200Kv motor, so an extra 3,7volts would add a theoretical 4400rpm.
 I’m sure I heard somewhere that three bladed props on model aircraft are less efficient than two bladed ones. Just a suggestion Dennis, but if you have a power meter you might like to try and see if the three bladed prop produces more thrust than the two bladed one before you try and send it up. (Just a thought)
By the way,….have you got pilot for it yet? :P
DennisZ
« Reply #4 on: May 02, 2013, 23:38:41 PM »
The motor is actually 900kv, used to swing 12x8 prop.
I am next to phoenix park four times a week these days, including Sat/Sundays ( kid doing rowing). So ... going electric is almost the only option.
