Author Topic: How wide is a wheel?  (Read 13777 times)
« on: July 28, 2008, 17:37:26 PM »
Hi All,
Just started (at last) my Slingsby Skylark project.
But I have a small problem.
It has one wheel in a box just behind the cockpit area, and I have to make sure there's enough width in the box at the 'keel and formers' stage.
So how wide is a 3" (75mm) wheel?
Searched the web but can't find anyone giving widths. :?
« Reply #1 on: July 28, 2008, 18:19:34 PM »
Hi Ron,
Difficult to say as that will depend mostly of the wheels maker...
But by experience, I would say between 20 to 30 mm... :?:
30mm would be the maximum size at this diameter...
« Reply #2 on: July 28, 2008, 18:45:27 PM »
Thanks, that might do.
I've got 32mm between box sides at the moment, provided I put any reinforcing on the outside of the box.
You don't stock wheels I suppose? :lol:
« Reply #3 on: July 28, 2008, 19:47:44 PM »
Should fit !
No, but we can have them  :D
If you tell me the specs you want.
I'll check in my stock aswell, I might have one to give to you...  :?:
cvanscho
« Reply #4 on: July 29, 2008, 13:45:05 PM »
How wide is a wheel?: about 5.4% of a length of string :roll:  :D !
« Reply #5 on: July 29, 2008, 23:30:18 PM »
OK then.
If my wheel box is 30mm wide that makes a piece of string about 55.5 cms.
I've often wondered how long a piece of string is. :lol:
Wonder if that applies to baler twine too.
This wheel has to be 3" dia, preferably with a Michelin tyre and air-cooled disc brake.
Hmmm :roll:
cvanscho
« Reply #6 on: July 30, 2008, 13:37:13 PM »
Well, now that we've sorted out how long a piece of string is, can we move on to determining how low "low" is (as in: "how low can you go?"):D ?
who really should be working..
« Reply #7 on: July 30, 2008, 13:48:04 PM »
To find out how low you can go you need some negative lift.
Now we're getting threads crossed.
Crossed threads?
That's string again isn't it. :?
Oh I give up :roll:
