Author Topic: Building board  (Read 18362 times)
Building board
« on: October 31, 2014, 23:23:46 PM »
All, what's the recommended building board to use under a set of plans?
I've considered MDF but it's very tough for inserting pins so any guidance is appreciated
Building board
« Reply #1 on: November 01, 2014, 14:21:55 PM »
Cover the MDF with cork tiles.
Building board
« Reply #2 on: November 01, 2014, 18:07:03 PM »
if you can get it Stephen - Sundeala. The railway boys use it as track boards, still needs a perfectly flat backing board.
Cheaper, easier to get option is plasterboard again on a perfectly flat substrate
http://www.sundeala.co.uk/
Building board
« Reply #3 on: November 01, 2014, 18:23:29 PM »
two Dublin based distributors in ROI OF Sundeala
Lawlor Office Supplies
        DUBLIN     Rep of Ireland
   +353 (0)1 837 1794
Woodworkers
   DUBLIN    Rep.of Ireland
   +353 (0)1 490 1968
Building board
« Reply #4 on: November 01, 2014, 20:10:58 PM »
Thanks for the replies the Sundeala stuff I've seen about alright, that'll do nicely.
mick a
Building board
« Reply #5 on: March 13, 2015, 15:14:04 PM »
hi
i use a half width fire door , got from demolition site
as its fire door very flat , to cover i use foam board from art shop
pins go in easy and stick also easy to replace
its good size to build up to 4 metre wingspan (2 metre each wing )
