SIGN THE PETITION!
https://ig-hangflug.eu/petition
Aerotow
take -off dolly
Topic: take -off dolly (Read 18574 times)
mick a
take -off dolly
May 23, 2016, 18:18:32 PM »
hi
has anyone got any plans or ideas for a good take-off dolly
i want one for the 1/3 ka3 , which has wing struts so cant rest wings on
Re: take -off dolly
May 26, 2016, 12:51:03 PM »
Hey Mike,
Yeah, with the stuts, you will need a low one alright.
I look at that and draw up something for you real quick
mick a
Re: take -off dolly
May 29, 2016, 08:30:15 AM »
thanks fred
star as always
Re: take -off dolly
Reply #3 on:
May 30, 2016, 12:15:03 PM »
Here you go
And while I was at it, did one for "generic" gliders.
I tried to keep it as low as possible, as I think, in my view, the trolley you see are too high. Lower, more stability I think.
So, who will be the first to build one?
Re: take -off dolly
Reply #4 on:
May 30, 2016, 12:34:47 PM »
OOppss, the files!
mick a
Re: take -off dolly
Reply #5 on:
June 10, 2016, 21:19:45 PM »
im going to build one
hopefully do my first tow in the next couple of weeks
will post results
Re: take -off dolly
Reply #6 on:
June 21, 2016, 08:05:52 AM »
Ok, had a bit of time this week, end, so I did this
Does not look too bad! Have to find wheels for it, and I'll bring it with me at the Cork event as we may do aerotowing to give it a try
Re: take -off dolly
Reply #7 on:
June 21, 2016, 15:09:32 PM »
Pity Corks so far away for me
That would have been a good weekend to try out the big Pawnee
Re: take -off dolly
Reply #8 on:
July 15, 2016, 20:46:57 PM »
Well, not with the kind of weather we had Andy!
Anyway, trolley built and approved... On the bench!
Very little modification to make it even better, and off we go
mick a
Re: take -off dolly
Reply #9 on:
July 17, 2016, 22:44:42 PM »
hi gents here is my ka3 take off dolly
going to try out on tuesday so will hopefully get vid of it
mick a
Re: take -off dolly
Reply #10 on:
July 22, 2016, 19:53:30 PM »
this ka3 is no longer .....sadly
tried to aerotow , and not enough experience on my side
pulled up to much , snapped the line at all most vertical at about 6 metres up
wings all good and rear of fuse
so will have to build new front end
Nhalyn
Where is gone my thermal ?
Re: take -off dolly
Reply #11 on:
July 27, 2016, 13:37:05 PM »
Sorry to come here after the action, but I don't understand why you need a dolly for a Ka3 ? I don't understand the problem with the wing struts ?
Most of times this sort of old gliders take off very easy and quickly, few meters, with a guy maintaining the wing horizontal for take off...
I wish you courage for the repair...
mick a
Re: take -off dolly
Reply #12 on:
July 31, 2016, 08:53:19 AM »
just wanted to make smoother as our field is a bit bumpy
the trolley worked fine , it was me who over imputted and pannicked , from behind it looked liked a dolphin rising and diving
we live and learn , repair is under-way
Nhalyn
Re: take -off dolly
Reply #13 on:
August 01, 2016, 09:04:36 AM »
If your field is "bumpy", it's another reason not to use a dolly... Your dolly bump on the field, the glider bump on the dolly, twice the effects !
Re: take -off dolly
Reply #14 on:
August 02, 2016, 07:46:02 AM »
I glued the dolly to the glider
Problem solved!
Aerotow
take -off dolly
