Author Topic: BigLift I - Rebuild  (Read 31503 times)
BigLift I - Rebuild
« on: April 07, 2009, 08:45:01 AM »
Tow plane is back on track !
Yesterday evening, started the re-covering of the beast.
Will be all bright yellow for better visibility  :D
Slowly but surely, I hope to have it ready for Retroplane along with the electric one.
DennisZ
BigLift I - Rebuild
« Reply #1 on: April 07, 2009, 11:16:51 AM »
how much power tow plane is expected to have ?
also what mods have to be made to convert "ordinary" plane to a tug ?
I'm thinking maybe my electric monster can be used for that ?
http://www.leinster-model-flyer.org/wordpress/wp-content/uploads/2009/03/dscf4146.jpg
80" wingspan
Dennis
BigLift I - Rebuild
« Reply #2 on: April 07, 2009, 12:18:00 PM »
Hi Dennis,
In general, well, that depend of what you have to tow !
The BigLift will go with a 26cc first, and if there is some interrest, I will certainly upgrade to a 50cc to go with bigger gliders.
The first thing you need, is a stable platform (the BigLift is born as a tow plane...) and power (tork). After that, everything else is in the way you fly the tow plane... Tow pilot is a R/C category on its own.
Then, of course, you need a release hook, as near as possible of the CG (we usually put it at the wing TE). Tow hook must be remotely controlled for the release.
I guess any planes can be converted as a tow plane, as 50% of the towing success are from the pilots, the rest, is the machine in my opinion.
DennisZ
BigLift I - Rebuild
« Reply #3 on: April 07, 2009, 12:31:58 PM »
Thanks Fred.
my plane certainly is nowhere near 50cc.
about tow hook: does it mean after glider has released its end, tug drops another ?
BigLift I - Rebuild
« Reply #4 on: April 07, 2009, 12:37:10 PM »
No worries, any power will do. That will only limit the weight of the glider you can tow !
My electric one will be for gliders up to 2 kg for example...
For the tow hook, no (well, not necesarely. I know some tow plane pilots who release the line before landing on a low pass...) but that is more an essential safety feature.
If the glider have a problem, the tow plane can always release. You save the plane...
BigLift I - Rebuild
« Reply #5 on: April 09, 2009, 10:36:55 AM »
Good colour Fred. I think we will see that in the air.
When do I get my hands on it?? :D  :D  :D  :D
BigLift I - Rebuild
« Reply #6 on: April 09, 2009, 11:49:46 AM »
On my dead body !  :P
Or when I want to fly my gliders really...  :P
BigLift I - Rebuild
« Reply #7 on: April 20, 2009, 08:49:13 AM »
The BigLift now sits on his wheels !
Servos are in the fuselage too !  :D
And no photos! Tonight!
BigLift I - Rebuild
« Reply #8 on: April 21, 2009, 11:02:03 AM »
So, here is the progress so far  :D
A little bit of work every now and then...
Going to be visible I'm sure...  :lol:
BigLift I - Rebuild
« Reply #9 on: April 21, 2009, 17:56:32 PM »
Corrrr, you've certainly got a big one Fred! :shock:  :oops:
BigLift I - Rebuild
« Reply #10 on: April 21, 2009, 18:56:08 PM »
Hey Fred. Is that the old MPX Big Lift.
BigLift I - Rebuild
« Reply #11 on: April 22, 2009, 07:22:05 AM »
Hey there  :D
Wel Keith, not that big, but all square, that make it bigger than that thing really is I think !
On the nose, a 26cc (originaly, this plane towed hundreds of gliders with a 15cc...), but if we have lots of interrest, I will go for a 45 / 50cc in the future... (The 26cc with the 18x6 pull 5kg static...)
Alan, this is an original vintage BigLift from Multiplex... About my age !  Pure unobtainium !  :D
Full functions, at the time, we used to put a video camera on it (there is a window on the belly), tow hook, top (gliders) and bottom (parachutes, banner) etc etc... All the linkage were push/pull with steel cables, but now updated to a more modern standard !  :)
Stephan
BigLift I - Rebuild
« Reply #12 on: May 12, 2009, 20:08:30 PM »
Fred, could you measure on your BigLift the incidence? Has your BL ailerons and flaps, if yes you could measure them  too  :D
Thanks
Stephan
BigLift I - Rebuild
« Reply #13 on: May 13, 2009, 16:55:29 PM »
Hey Steph, sorry for the late reply !
Will do asap! Have to set it up in the garden to do it.
But the wing incidence pins should be built in no?  :?:
BigLift I - Rebuild
« Reply #14 on: May 13, 2009, 17:02:16 PM »
Maybe Stephan means the incidence between the wing and the tailplane?  :?: :?:
