Author Topic: Large B52 PSS  (Read 144884 times)
B52 progress
« Reply #15 on: October 22, 2009, 21:44:30 PM »
A big thanks Joe, for the address, Simon Cocker is one of the top PSS flyers in the U.K. he was flying large models when the rest of us were flying trainers. I will send Simon an e-mail later this week.
B52 progress
« Reply #16 on: October 22, 2009, 22:21:09 PM »
Hi all
I finished the glassing of the center section tonight, so hopefully I will get the fuselage done over the weekend as planned.
O.K. fellow pilots, I need your help if possible. I have found a company in Portadown who can vacuum press the engines in plastic, however I need to supply the plug, therefore, do any of you have, or know someone who has a wood turning lathe and could turn out a set of engines.
I could make the engines out of balsa, as I did with the test model, however I would like to be able to replace these parts quickly if any got damaged in landing, so plastic engines would be quickest and lightest option.
Could you contact me if any of you can help?
Large B52 PSS
« Reply #17 on: October 23, 2009, 08:04:21 AM »
Hey John,
The father in law is equiped with a turning machine !
I go and visit him next week end...
Do you have a plan for the engine pods for me to have a look ? :?:
Large B52 PSS
« Reply #18 on: October 23, 2009, 11:43:24 AM »
You could make one out of balsa and use it as a plugs for the vacuum forming?
Large B52 PSS
« Reply #19 on: October 23, 2009, 14:53:03 PM »
Or Foam + glass for the mould.
Ah well, anyway, let me know if you still need some wood to be turned !  :D
b52 progress
« Reply #20 on: October 23, 2009, 15:16:47 PM »
Thanks guys
I was thinking if I could get 2 engines turned on a lathe, then I could join them and add fillers to the center section. D.Cairns from the USA, used the same setup on his fantastic B52 here are a few pics from Dave's RC Groups build log :
Engines produced on a lathe then glued and filler added.
Vacuum formed in plastic
These pics give you an idea of what I am try to do
B52 progress
« Reply #21 on: October 24, 2009, 21:11:28 PM »
Hi Fred
Thanks, I could post you a copy of the engines from the plan, if you or still going to your father in laws. Post your address on my private message board and I will get them of to you ASAP.
B52 progress
« Reply #22 on: October 26, 2009, 22:27:12 PM »
Hi Fred
I have found a teacher at my local tech college, who is going to turn out the engines on a lathe next week, so thanks for the kind offer to do them.
Worked on the B52 tonight, sorry no photos, however I will post some later this week.
Large B52 PSS
« Reply #23 on: October 26, 2009, 22:37:52 PM »
That's not allowed John :x  If you work on it you MUST take pics :wink:
Large B52 PSS
« Reply #24 on: October 27, 2009, 07:15:51 AM »
Oki Doki ! :D
And same as Bill, where are the photos ??  :P
Large B52 PSS
« Reply #25 on: October 27, 2009, 09:08:10 AM »
John, may I respectfully bring to your attention the rules of being a member of this forum.
Rule 101
Section 572,
Sub-section iiiv
Division aa
Chapter 13
Paragraph 42 states:
Any member failing to comply with any part of the above mention rule. Forthwith, and hereafter to be referred to as the , “Photograph rule” Shall pay, as a penalty, to each and every other member of the I.S.R. forum, and amount not greater than the inflation index linked cost of one imperial pint of each of the other members favourite alcoholic beverage for each and every day, (a day being referred to as any complete 24hour period  beginning and ending at 12 midnight Universal Standard Time) for such duration as the aforementioned photographs are absent from the published articles on the above mentioned forum………….ZZZZZZZZZzzzzzzzzzzzzzzzz :roll:
In other words WHERE’S THE  BLOODY PICTURES??? :!:
lothar4862
  • navigare necesse est
Large B52 PSS
« Reply #26 on: October 27, 2009, 13:16:37 PM »
:lol:  :clap:  :lol:
Keith, You should make poltical cabaret!
You made my day.
Regards
 :D Lothar :D
and now back in airplanes ;-)
Large B52 PSS
« Reply #27 on: October 27, 2009, 14:09:44 PM »
Mine's a pint a plain thanks  :wink:
Large B52 PSS
« Reply #28 on: October 27, 2009, 22:07:19 PM »
err.. can I have a Bulmers?
B52 progress
« Reply #29 on: October 27, 2009, 22:29:42 PM »
WoW !!! you guys take no prisioners
O.K. well here are a few pics of the work so far, as the photos show, I finished the center section over the weekend and fitted the tall and fin sections in place. I used expanding foam to fill up the gaps in the wing seating area and shaped to suit the front fuselage area. I will finish this off with light filler and sand smooth.
I did not glass the fuselage as planed over the weekend due to a few cracks discovered at the tail, therefore I will have to strenghten this section from the inside with ply and glass cloth, better to be safe than sorry!!.
Expanding foam used to fill in all the gaps around the leading edge.
Photo  shows the flaps in the landing position.
I think I need a bigger Workshop
Well that's it for now, so far so good!
