Author Topic: good 2.5m+ sailplane - which one ?  (Read 40450 times)
Brian
« Reply #15 on: January 06, 2010, 19:38:11 PM »
No prob,,s John.
Brian
Serious Power
« Reply #16 on: January 13, 2010, 08:07:16 AM »
So Dennis, ……… the forum is awaiting your decision! :)
Which model are you going for, and what type of servos are you gonna fit in it? :?:
DennisZ
« Reply #17 on: January 13, 2010, 15:21:06 PM »
- Spirit Elite
- MG servos for flaps only
« Reply #18 on: January 13, 2010, 17:39:33 PM »
Well done Dennis! :clap:
I had an Elite. Built it from a kit. Flew on no more lift than a rabbits fart. It would float around for hours. :D
How will you launch it, bungee?  It would probably be a good model to tow, if you wanted to give that a try again in the summer.
DennisZ
« Reply #19 on: January 13, 2010, 19:47:05 PM »
Thanks Keith,
thats is ARF, they tend to be bit heavier that built ones.
Bungee, yes ... if our Club will allow me  :?
I do have a plan to install proper tow release ... at some stage .
Dennis
DennisZ
« Reply #20 on: February 01, 2010, 21:27:18 PM »
So, my bird has arrived !
Actually, it arrived week ago, it took some time to get replacement servo http://www.leinster-model-flyer.org/wordpress/?p=275 .
Now, my 6ch radio does not have CROW braking mixing so idea is to configure ailerons as flaperons (channels 1 and 6) and have flaps on channel 5.
This will allow me to use throttle stick to move both ailerons up or down and have on-off flaps.
I may have to buy servo reverser for one of flaps or simply mount one servo "in reverse" .
Ok, back to the bird ...
there are couple of disappointing moments :(
- steel wing joiner is about 5 mm longer than it should be
- servo hatch covers are either completely of wrong size or the opening for servo arm was cut on a wrong side ... turned 90 degrees
Also my choice of servos was not very good - looks like aileron servos are about 2mm too thick.
Hopefully I'll manage to fix all that.
« Reply #21 on: February 02, 2010, 13:49:51 PM »
Hey Dennis Glad your plane has arrived. Allow me to tell you a little tale about using flaperons. :!:
The picture at the end of this posting is the fuse’ of a little mouldy I have. There are a total of 5 breakages’ along it’s length. :(
I couldn’t understand why this little Filip 400 would often come into land nicely, then suddenly drop one wing and cartwheel along the landing area, breaking the fuse with the inertia. :cry:
Then I was then told about the effects of “Wash-in” and “Wash-out” at the wing tips. :?:
The end result was that instead of using the ailerons as flaperons when landing (Which increases Wash-In) I was told to make both ailerons move UP to become Spoilerons. This increases Wash-out which tends to stop the wing from tip stalling. :D
Result: Perfect landing every time! (Well………nearly perfect. Well,………..landings without damage, lets say that! :oops: )
You might want to bear this little story in mind
Oh, by the way. The Filip still flys, although not quite as well as it used to !!
DennisZ
« Reply #22 on: February 02, 2010, 22:57:14 PM »
Thanks Keith.
That is exactly what I was going to do: flaps down, ailerons up = crow braking.
DennisZ
« Reply #23 on: August 02, 2010, 23:42:48 PM »
OK, it took me only 7 month to "build" ARTF model :)
have not flown yet
« Reply #24 on: August 02, 2010, 23:56:56 PM »
Looks good Denis :clap:
« Reply #25 on: August 03, 2010, 06:58:59 AM »
Looking at the picture of the Elite on your floor Denis, it looks to me as though the wing is a polyhedral. Is that right? :?:
You’re going to enjoy flying this one, :D  if only because you’ll know in the back of your mind that you can slow her down for landing. :wink:
Hopefully we’ll see her up on the Big L soon, or at the September Glide-In?
DennisZ
« Reply #26 on: August 03, 2010, 08:48:10 AM »
Well, the spec says it is polyhedral . For me, the middle part of that wing is rather flat.
DennisZ
made it
« Reply #27 on: August 09, 2010, 10:17:32 AM »
Well, she made the first flight at Killakee north slope this Saturday.
Flew fantastic :) need more practicing on landing skills .
(no footage of that).
Next day, with camera ready, we went to the Phoenix park.
With proper bungee - big thank to Peter.
Managed only few flights when guys with big motors arrived ...
[youtube]http://www.youtube.com/v/Kok-lnLyq8o[/youtube]
[youtube]http://www.youtube.com/v/3lOzND-Z0Uk[/youtube]
[youtube]http://www.youtube.com/v/24GjWmLw1R8[/youtube]
[youtube]http://www.youtube.com/v/BO_-_ICCUSA[/youtube]
[youtube]http://www.youtube.com/v/axTzPBvPM5A[/youtube]
[youtube]http://www.youtube.com/v/XZ4azfYvn0U[/youtube]
[youtube]http://www.youtube.com/v/YkUd-rKWh5c[/youtube]
« Reply #28 on: August 09, 2010, 17:24:52 PM »
The first launch was a bit of a surprise!!!. :lol:
Don’t know if this is any use to you Dennis but when I had a bungee the instructions told me that the shock chord would extend to four times its contracted length. From what I saw on the vids I would have thought you could have stretched yours rather more, and so got greater height.
DennisZ
RIP
« Reply #29 on: June 18, 2012, 08:46:36 AM »
The bird had lived short, but beautiful, life ...
reduced to pieces this weekend - nose dive to tarmac   :cry:  :cry:  :cry:
