Author Topic: Slingsby Skylark 2  (Read 130926 times)
Slingsby Skylark 2
« Reply #15 on: November 13, 2010, 19:45:44 PM »
Quote from: "billscottni"
At smaller scales full size airfoils don't usually work. it's all to do with Reynolds numbers.
As Alan says Chris Wiliams advocates the Quabeck sections even in his 1/3 scale aircraft
Ah, you got there before me Bill  :D  :D
Slingsby Skylark 2
« Reply #16 on: November 13, 2010, 20:26:43 PM »
Ah yes, Reynolds Numbers.
Wikipedia:
If an airplane wing needs testing, one can make a scaled down model of the wing and test it in a wind tunnel using the same Reynolds number that the actual airplane is subjected to. If for example the scale model has linear dimensions one quarter of full size, the flow velocity of the model would have to be multiplied by a factor of 4 to obtain similar flow behaviour.
Slingsby Skylark 2
« Reply #17 on: November 13, 2010, 20:27:28 PM »
One of our club members is a real airfoil buff. Right in to the whole mathematics of the things, which is how I know it.
If anybody is looking for good, SIMPLE, explanations try:
Understanding Aerofoil Date for RCSoareres, by Denis Oglesby. Available from Traplet
and/or
Understanding Polars without Math by Bill & Bunny Kuhlman available from
B2 Streamlines, http://www.b2streamlines.com/
Slingsby Skylark 2
« Reply #18 on: November 13, 2010, 20:45:27 PM »
Thanks for that Bill.
I shall certainly look into those books.
B2streamlines also has a good few links to aerofoil plotting apps for Mac. :clap:
Slingsby Skylark 2
« Reply #19 on: November 19, 2010, 14:25:10 PM »
Finally started some construction. I'm starting with the fuselage. According to the RC Model World magazine article on this plan, the Fuselage is supposed to be built on a jig in one piece (e.g. using whole formers not half formers), not sure if you understand what I mean. But there was no information in the article or the plan as to how the formers were to be attached to this jig or how they were to be aligned. So after much head scratching I decided to build the fuselage in two half's.
Slingsby Skylark 2
« Reply #20 on: November 19, 2010, 18:40:07 PM »
Hi Alan,
Nice job.
Can't think how you could do that fuselage on a jig.
Wonder how they did the full size one in the factory :?:
If it was a boat the keel would have been set up first and the frames fitted to that at the appropriate angles.
I guess the keel could have 'legs' down to the baseboard to keep it at the right height, and maybe even fit the legs into slots in a jig to hold it all up.
Bit of a procedure I would have thought.
Great work though. :clap:
PS. What's that glue?
Slingsby Skylark 2
« Reply #21 on: January 06, 2011, 10:01:18 AM »
Happy New Year All.
Finally warmed up enough to get some work done. Photos below.
Ron: The glue I'm using is some sort of French white wood glue that I got at Retroplane. It's called Pattex I think, I'm sure Fred will know exactly what's it's called. It seems pity good.
Slingsby Skylark 2
« Reply #22 on: January 06, 2011, 19:16:34 PM »
Very good Alan!
Sheeting in plywood ?  :?:
Retroplane glue, very good stuff indeed !  :clap:
Slingsby Skylark 2
« Reply #23 on: January 06, 2011, 19:42:25 PM »
Hi Fred.
No I'm sheeting it in balsa. The area around the cockpit and where you hold the fuselage when launching will be reinforced with extra sheeting on the inside to stop it getting crushed, at least thats what the plan says.
Slingsby Skylark 2
« Reply #24 on: January 17, 2011, 18:47:21 PM »
Another update. I have built the tailplane. Again I have deviated from the plan. The plan called for a solid balsa tailplane. But to try and keep the weight down at the rear I decided to make a built up tailplane sheeted with balsa. Hopefully that will reduce the weight at the rear-end a bit meaning less lead in the nose. Photos below.
Slingsby Skylark 2
« Reply #25 on: February 06, 2011, 12:42:59 PM »
Hi All.
I have started work on the wing center section. It's built in two half's and joined together later as there is a dihedral angle built into it.
Here are the dihedral brace's
Slingsby Skylark 2
« Reply #26 on: February 06, 2011, 12:54:11 PM »
Nice Alan, Wish my KA-3 was progressing as quickly.  :x
Suffering alack of enthusiasm at the moment, probably as a aresult of too little flying.  :cry:
You need some return from your building efforts
Slingsby Skylark 2
« Reply #27 on: February 06, 2011, 13:05:48 PM »
looking good alan  :clap:
it's coming along nicely
bill it's hard to get motivated sometimes maybe we'll get out next sunday  [-o<
Slingsby Skylark 2
« Reply #28 on: February 06, 2011, 14:55:31 PM »
Thanks Lads.
I know how you feel. But what I do is look at the pictures from Retroplane and the Retroplane DVD and that gives some enthusiasm to get going. I'm dying to get some flying done myself. I think the last time I few was in September or October. The last time I few the K8 was at Retroplane in July.
Slingsby Skylark 2
« Reply #29 on: February 06, 2011, 15:11:14 PM »
Thanks Alan, tried the DVD's, flown the sim, still no good. Last time I flew was 12th Dec 2010. Not just the flyig that's bugging me, few probs in my personal life too, like an ex-wife! :x
