Author Topic: A big box...  (Read 86351 times)
Frederic
A big box...
« Reply #60 on: May 06, 2012, 12:38:02 PM »
Whaaa !  :clap:
Une question : tu n'as que le marron fonçé comme couleur de découpe. Bleu ou rouge, ce serait plus sympa ! Et ça changerait un peu.
Bises
Frédéric
More water !
A big box...
« Reply #61 on: May 06, 2012, 14:44:09 PM »
Nice work Fred.  :clap:  :clap:
A big box...
« Reply #62 on: May 06, 2012, 16:05:50 PM »
Que la force soit avec toi :D
A big box...
« Reply #63 on: May 06, 2012, 20:17:35 PM »
Quote from: "Frederic"
Whaaa !  :clap:
Bises
Frédéric
Tiens, en parlant couleur de ois, je suis content, c'est pas noir, mais juste brun. Le bois est donc pas vraiment brulé en profondeur  :D
Talking a bout the colour pf the edge, I'm happy, as this is not dark (black) but light brown, meaning that the machine / power is setup perfectly as the wood is only very lightly burn  :D
Anyway, thank you all. I am now waiting for the wood, and I get started on the Quarks (I have around 50 pre-ordered!  :shock: )
After that, time to cut a few vintage gliders prototypes  :D
A big box...
« Reply #64 on: May 07, 2012, 10:19:41 AM »
Have you been holding out on us Fred. What are they? Go on, give use a hint  :D  :D  :D
A big box...
« Reply #65 on: January 11, 2013, 20:05:44 PM »
Ok, I bring that one up, as I found a video of the machine cutting plywood.
If you really are interrested in that sort of things!
Power : 60%
Speed : 40
Wood : 3m Plywood
You can see o the second part of the video what happen when you don't do polylines! That double the cutting time!
Raw video, as I am lazy! And thanks for my little helper  :D
http://vimeo.com/57200544
A big box...
« Reply #66 on: January 11, 2013, 23:52:25 PM »
That's a cool machine Fred :-)
A big box...
« Reply #67 on: January 12, 2013, 08:15:01 AM »
c est de la bombe mon fred, :clap:
je vais acheter les 2 bouteilles et les expedier rapidos,
 :?: tu recrutes jeune ton personnel :wink:
A big box...
« Reply #68 on: January 12, 2013, 08:21:12 AM »
La vitesse de coupe est impressionnante, mais alors : ça fume!!
Tu découpais un puzzle 3D de dinosaure?  :?:
A big box...
« Reply #69 on: January 12, 2013, 18:05:12 PM »
Impressionnant , pas trop dangereux ce laser???
h quand le sabre laser pour faire les découpe?.
A big box...
« Reply #70 on: January 14, 2013, 09:38:48 AM »
Quote from: "orionis"
Et encore, je suis pas a fond  :lol:  Mais apres, tu risque d'avoir des problemes de coupe franche. La, c'est regle pil poil, the bois est juste brun clair  :D
Mais c'est vrai que ca fume quand meme pas mal!
Oui, puzzle 3D de Dino trouvé sur le net  :D
Quote
Ah ben la, faut pas y mettre les doigts!
Y'a une securité quand meme qui desactive le laser si tu ouvres la machine... Debraillable, car il te faut acces au laser pour la calibration.
Le plus dangereux, c'est que c'est invisible, mais la plus dangereux, c'est le tube lui meme... Y'a un arc electric qui se forme, dans les 30 ou 40 000 volts... La, j'y vais pas derriere!
Pour la calibration, tu brules des cibles en papier... Ca brule bien!  :lol:
DaveMc
A big box...
« Reply #71 on: January 20, 2013, 19:25:26 PM »
Nice one Fred, you really do take this to the next level.
Well done
D
A big box...
« Reply #72 on: January 28, 2013, 18:48:48 PM »
Lasers?
You ain't seen nuffin yet...
"...the system sliced through a 15mm- (~0.6 inches) thick steel girder from a kilometer away."
http://singularityhub.com/2013/01/07/german-military-laser-destroys-targets-over-1km-away/
A big box...
« Reply #73 on: January 30, 2013, 19:36:43 PM »
Quite amazing how they do it. How do they focus the beam at such a distance? :!:
Raises the old question, is light a wave form or particles?  :?:
(Hmmm, E=MC squared, take away Schrödinger’s Cat & the number you first thought of  Zzzzzzzzzz :? )
A big box...
« Reply #74 on: January 30, 2013, 19:51:04 PM »
Last thing I heard, it depends how you look at it.
Errr.... Maybe not in this case   :x
