Author Topic: cutting rib notches in wing trailing edge  (Read 13665 times)
zug
« on: October 25, 2017, 14:11:03 PM »
Hi Guys,
I'm building my first model glider - an Echo Fox. The wing ribs on this model are notched into the wing trailing edge. Is there any recommended technique for cutting out the notches.
Do you just mark the notch out in pencil and then cut each side of it with a very fine saw and then chisel out the middle bit? The notches are small, but I'm guessing there is no special tool for doing it?
Many thanks,
Zug
Re: cutting rib notches in wing trailing edge
« Reply #1 on: October 25, 2017, 14:29:23 PM »
If it's 1/16" or 1.5mm slots you need, try taping 2 hacksaw blades together and aligning the centre to the mark.
zug
« Reply #2 on: October 26, 2017, 21:34:26 PM »
Thanks Bill.
The ribs are actually 3 mm wide. So I might try 3 blades taped together.
Zug
