Author Topic: building the elasticity planne 15g  (Read 15884 times)
alle
« on: November 15, 2008, 18:15:00 PM »
Varetas de balsa, ca, estilete e filme plastico de embalar alimentos.
    Sticks of balSticks of balsa, ca, stylus and plastic film for packaging foods.
 Quino
alle
« Reply #1 on: November 15, 2008, 18:18:42 PM »
mais fotos  / more photos
 Quino
alle
« Reply #2 on: November 15, 2008, 18:19:23 PM »
 Quino
alle
« Reply #3 on: November 15, 2008, 18:20:13 PM »
more photos
 Quino
alle
« Reply #4 on: November 15, 2008, 18:20:55 PM »
more photos
 Quino
alle
« Reply #5 on: November 15, 2008, 18:21:41 PM »
more photos
 Quino
alle
« Reply #6 on: November 15, 2008, 18:23:32 PM »
more photos
 Quino
alle
+ Photos
« Reply #7 on: November 28, 2008, 18:15:32 PM »
 Quino
alle
+ Photos
« Reply #8 on: November 28, 2008, 18:17:05 PM »
 Quino
alle
+ Photos
« Reply #9 on: November 28, 2008, 18:22:31 PM »
photo of bearings, the propeller will be replaced by one that I am doing (10 inches
 Quino
alle
« Reply #10 on: December 01, 2008, 22:24:09 PM »
please comment, accepted suggestions.
hug
alle
 Quino
« Reply #11 on: December 02, 2008, 00:20:40 AM »
That is really cool, you truly are building the plane from scratch even the prop.
I have some friends that left the building of bigger planes to started and build only light small one like those.
They are using the electronics from the Kyosho Minium ending with a plane with around 30gr.
How much is the weight of that one that you built? It seems to be powered by a rubber band is that correct?
alle
« Reply #12 on: December 02, 2008, 18:43:57 PM »
É isso mesmo o motor é de borracha,  somente a hélice vai ser outra, aquela foto da hélice foi só mostrar o mancal, vou a hélice que está no outro post, desculpe-me pelo ingês ruim.
Voçê disse aluminio?
abraço
alle
That's right the engine is rubber, only the helix going to be another, that photo of the propeller was the only show bearings, I am the propeller that is in another post, excuse me for bad English, is that these are the same, only usually post after flying, not to tips wrong.
You said aluminum? must be pretty hard, and with thirty (30) grams, cool.
hug
alle
 Quino
« Reply #13 on: December 02, 2008, 21:52:10 PM »
Ok sem problema da para perceber! :)
Nao era aluminium, estava a falar da Kyosho Minium uma cessna 2.4Ghz que a Kyosho vende e que e super leve. Esse meu amigo retirou a electronica e construiu tal como voce um modelo para indoor super leve em balsa e glad (aquele plastico para embalar comida) que ficou num total de 30gr.
I as talking abou the Kyosho minium instead, the electronics. He used the electronics to build a small indoor plane much like yours all from balsa and Glad ( that plastic wrap for food). That in the end weighted 30gr.
alle
« Reply #14 on: December 03, 2008, 20:35:41 PM »
Ei ice wind,  seu portugês está muito bom,  estou começando no vôo livre ainda tenho muito a aprender, tenho um colega que fez a mesma coisa que o seu, segue uma foto  e o link de montagem.
abraço
alle
ice wind, his Portuguese is very good, I'm starting at free flight still have a lot to learn, I have a colleague who did the same thing as his own, following a photo and link to assembly.
hug
alle
http://www.e-voo.com/forum/viewtopic.php?t=44849
 Quino
