Author Topic: Wing Setup  (Read 15697 times)
error404
Wing Setup
« on: October 16, 2009, 15:13:25 PM »
I am putting together a flying wing and just got stuck at this (simple) problem.
When i push the stick up, the right aileron moves up and left aileron down and opposite when stick is pushed left!
When i push the stick left, both ailerons go up and opposite when pushed right!
I do not plan on flying with my optic 6 sideways :)
What is the best solution i could try for this? I did not have time to try anything yet but will do over the weekend, read the manual again.
Using Channel 1 for right servo and Channel 2 for left servo as suggested in manual, also not using v tail mixer but have one if i need it.
Ta
Anthony
www.rubberprintdesign.com
Wing Setup
« Reply #1 on: October 16, 2009, 15:26:44 PM »
You will need to use a delta mixer. Thats a mixer specially made for flying wings. The  mixer is probably programed into your transmitter already, you just need to turn it on. I assume the Optic 6 transmitter has a delta mixer.
error404
Wing Setup
« Reply #2 on: October 16, 2009, 15:32:27 PM »
Alan,
It mentioned to switch on Elevon Mixing which i did.
I will check tonight for the delta mixer, i'm sure the function is on it.
Thanks
Wing Setup
« Reply #3 on: October 16, 2009, 15:36:22 PM »
I think the Elevon mixer is the same as a delta mixer. If thats the case may be the servos are connected to the wrong channels.
error404
Wing Setup
« Reply #4 on: October 16, 2009, 15:38:09 PM »
I will try that.  :oops:
Wing Setup
« Reply #5 on: October 16, 2009, 15:42:57 PM »
Don't worry. I have made the same mistake as well. Had quite a number of head scratching moments   :D  :D . Trial and error.
Wing Setup
« Reply #6 on: October 16, 2009, 16:48:28 PM »
Hi Anthony,
Or swap channel 1 and 2 on the receiver...
I had a few MC18 nonsense moments too...  :P
error404
Wing Setup
« Reply #7 on: October 19, 2009, 09:27:16 AM »
Problem fixed, just had to swap the channels.
