Author Topic: Free F-4 Phantom PSS plan  (Read 23280 times)
« on: January 13, 2010, 22:39:01 PM »
Hi All
I have a plan for an F4 Phantom PSS from the RM Green selection of slope soarers. If any pilot would like this plan for free, I will post it to you.
let me know ASAP
johnp
« Reply #1 on: January 13, 2010, 22:45:20 PM »
Very generous of you John !  :clap:
Tempted, but will be a shame not to build it ! Too many projects already  :(
DennisZ
« Reply #2 on: January 13, 2010, 23:14:44 PM »
Hi John,
may I have it please.
Thanks
F4 plans
« Reply #3 on: January 14, 2010, 17:11:20 PM »
Hi Dennis
the plan yours
e-mail me your address, and I will get it posted ASAP
Johnp
plans
« Reply #4 on: January 15, 2010, 14:02:59 PM »
Hi Denis
posted your plan today, not sure how the southern post takes, I sent it first class, hopefully a day or two.
JohnP
DennisZ
« Reply #5 on: January 15, 2010, 14:18:41 PM »
Thanks John!
It is going be interesting build.... and long ....
F4
« Reply #6 on: January 15, 2010, 14:23:04 PM »
No problems Dennis, hope you enjoy the model, maybe you should copy the plan and make it 100% bigger, now that would be somthing to see on the slopes??
« Reply #7 on: January 15, 2010, 14:36:50 PM »
And the best part is.... I have a plan copier  :mrgreen:   O:)
DennisZ
« Reply #8 on: January 18, 2010, 10:10:25 AM »
Quote from: "JohnPearson"
ok, the plan has arrived this morning.
now questions:
- how do you, gurus, transfer those lines onto material (wood/foam) ?
up until now I used to just glue a plan to the foam sheet and cut through the paper ...
- Fred, can your plan copier to scale up A0 page ? say make twice large (that will be four A0)
« Reply #9 on: January 18, 2010, 10:19:20 AM »
Hi Dennis,
Several methods here...
One explained here : http://www.rcgroups.com/forums/showthread.php?t=77687 (from a copy)
More here in French (google..) http://www.retroplane.net/forum/viewtopic.php?t=81
Same thing, but from a laser print and then an iron. That transfer the carbon on the wood (but same, you need to make copies of the parts you want to transfer...)
And I use none of them! I use a pin to mark the parts on the wood, then, you have to trace all the lines. Time consuming, but works great.
A little tip, useful for the ribs etc etc, is that once I have all the parts drawn on the wood, I glue another sheet below it with 2 or 3 drops of CA, and cut them on the fret saw... 2 parts are cut at the same time.
For the copies, I can do a copy, no problem. Save it as PDF, jpeg etc etc.
The copier have an enlarge function, up to A0, but not too sure how that would work to scan only one part to enlarge them if you want 4 A0!  :?:
« Reply #10 on: January 18, 2010, 12:49:25 PM »
Fred,
Could you scan it, enlarge, convert to pdf and then tile it to give you the right size for the printer? :?:  :?:
« Reply #11 on: January 18, 2010, 13:03:56 PM »
Hey Bill,
Yep, I can scan and convert to PDF.
Do you know a software that will tile to A0 or A1 ?  :?:
DennisZ
« Reply #12 on: January 18, 2010, 13:36:54 PM »
Quote from: "billscottni"
I've got an idea :
- take a photo
- load image into Profili2
- print it tiled for your printer !
(yes, I have licensed Profili 2 Pro)
« Reply #13 on: January 18, 2010, 16:08:09 PM »
Hey Bill,
Should just be a matter of setting the paper size in the print dialogue box
