Author Topic: ASH25 - 1/4 scale  (Read 63534 times)
ASH25 - 1/4 scale
« on: January 15, 2012, 10:25:23 AM »
Alright, time to get some old projects to move forward!
This time, next on the line, is my ASH25.
A few specs :
Fuselage lenght : 2.10m
Wing Span : 6.5m
Profile : E68 - 67 - 66 evolution
Weight : should be around 10 - 11 Kgs
The fuselage (look at that smily face!  :D )
The fuselage come from Gewalt, everything else will be hand made.
A bit of work was already done. I made the tailplane more than a year ago, and the wing cores were cut by Joe (thanks Joe  :clap: ).
And that take room!
As a reminder, I use this method for my wing spars :
http://www.gliderireland.net/index.php/techniques/vertical-wing-spars
Wings will be in 2 pieces.
So first, you start with the wing sheeting, the top first. The sheets are linked the usual way for this kind of work, evrything is glued with PU, and bagged for 24 hrs.
That gives you this stuff :
You can see here the "channel" for the vertical spar, before being cut all the way through. This way the profile is not "disturbed".
With a screw driver in my case, remove the remaining foam, and free the slot for the spar
It is very important to do all the work on the wing,while they seat on their foam cores to make sure they are straight!
Like on the mini how to link, the spar is then added, and cut to size.
The spar will be epoxied in place, wrapped in carbone, and everything will be bagged to make sure everything stays where they supposed to be!
More photos soon! (still drying!)
ASH25 - 1/4 scale
« Reply #1 on: January 15, 2012, 12:13:10 PM »
Beautiful fuselage Fred, but I think you need a better looking model :wink:
Be really interested in seeing that fly :clap:
ASH25 - 1/4 scale
« Reply #2 on: January 15, 2012, 15:03:56 PM »
Great job Fred. Very informative. Keep the pictures coming.
ASH25 - 1/4 scale
« Reply #3 on: January 15, 2012, 15:13:53 PM »
Fred,...what do you mean by "Bagged"? Are you vacuum bagging this wing?
K. :?:
ASH25 - 1/4 scale
« Reply #4 on: January 15, 2012, 15:25:23 PM »
Thanks guys :)
Keith, yep, the wings are vacuum bagged
ASH25 - 1/4 scale
« Reply #5 on: January 15, 2012, 20:47:56 PM »
falut Sred
11 kilos, ca me parait un peu light pour cette taille de machine. Pour info je pense sortir le DG pour 14 ou 15 kilos.
a+
ASH25 - 1/4 scale
« Reply #6 on: January 16, 2012, 08:21:45 AM »
Salut Air One,
Bah non, ca reste quand meme une machine au 1/4, donc assez petit  :D
Bon, comme tu m'as mis un doute, j'ai fouillé le Interweb, et chez les GPR, un gars le sort au 1/4 a 8kgs  :D
About the glider projected weight, I say 10 / 11Kgs, but 14Kgs seems more realistic.. In fact, even if the WS is 6.5m, this is still only a 1/4 scale machine.
Looked over the internet for some reference, and some guys are doing it at 8Kgs  :D
ASH25 - 1/4 scale
« Reply #7 on: January 16, 2012, 17:00:14 PM »
bon ça vole en avril :mrgreen:
ASH25 - 1/4 scale
« Reply #8 on: January 16, 2012, 18:58:54 PM »
En avril? Pff, dans 15 jours, oui [mode pression ON]
ASH25 - 1/4 scale
« Reply #9 on: January 18, 2012, 08:35:10 AM »
OHH  joli projet.
Fred, t'es pas obligé de faire la gueule, sur les photos........ :lol:
ASH25 - 1/4 scale
« Reply #10 on: January 18, 2012, 13:02:38 PM »
Yeah, that's to scare the crows!  :lol:
April.. hmmm, too cold in the garage for the resin  :!:
mat2verre
ASH25 - 1/4 scale
« Reply #11 on: January 18, 2012, 17:24:15 PM »
Hooo que c'est bôôôôô! Fais pas la gueule Fred!!!
Biz @+
Mat
ASH25 - 1/4 scale
« Reply #12 on: January 18, 2012, 19:08:42 PM »
Je suis pas tibulaire, mais presque  :mrgreen:
(can't translate that!  :P )
ASH25 - 1/4 scale
« Reply #13 on: January 18, 2012, 19:14:12 PM »
utilise la polyester , c est moins chiant :mrgreen:
ASH25 - 1/4 scale
« Reply #14 on: January 18, 2012, 19:28:52 PM »
:lol:  :P  :P
