Author Topic: Lockheed U2r PSS  (Read 83655 times)
Lockheed U2r PSS
« on: May 23, 2006, 01:23:27 AM »
U2r PSS from a Paul Janssens plan http://www.pjmodelclassics.be/
Span 210 cm
Lenght 121 cm
Weight 1.3 KG
i have fancied the idea of building some PSS planes for a while now and have been collecting a few plans with a view to building them over the coming year.the U2 was one of the first i got my hands on.i've always liked the look of the U2,especially in NASA colours and it seams well suited to PSS.with those long, high aspect wings it's almost glider like.which means it should fly well even in light lift conditions.so here goes
FUSELAGE:
the fuselage is made using the lost foam method:
a foam plug is made by using side and top view templates to cut a two dimensional fuselage.
the third dimension is added by sanding and using cross section templates to get the shape right.next the fuselage is covered in packing tape and treated to a coat of wax.
then three layers of glassfibre are applied using finishing epoxy.when that starts to cure the whole fusealge is covered in a thick coat of epoxy microbollons mix.when cured the epoxy microballoon coat is sanded to leave you with a smooth hard finish.
thats about as far as i gotten.
the next step is to cut an access hatch in the fuselage and use acetone to melt the foam (hence the name "lost foam method") out and remove the tape,leaving me with a nice glassfibre fuse for my U2.i want to to fill a few little bits and get a better shape in places before i melt out my foam plug.
this is what we're aiming for
2D fuse:
3D fuse after lots of sanding
fuse covered in tape ready for glassing
sanded glass fuse given a light coat of primer to see what the surface finish is like.this will need a little more work.
thats all for now.
next: finishing the fuse and cutting the foam wings and tail group
Lockheed U2r PSS
« Reply #1 on: May 23, 2006, 09:23:33 AM »
Very very nice !!
You've used a filler on top of the brown tape ? Is that correct ?
Very good looking fuselage !! I like that !
Lockheed U2r PSS
« Reply #2 on: May 23, 2006, 10:38:22 AM »
thanks Fred.
it's getting there.not bad for first attempt.need to go around the fuse and fill all the humps and bumps,and sand again.that should give me a nice smooth finish.the photos make it look a lot better it actually is.
i've learned a lot about this method and will totally use it again.would recommend starting with a much smaller fuselage though.the U2 took a good bit of time.lots of glass cloth and lots of epoxy!
no?,no filler on brown tape.here what i've done again:
shaped foam plug is covered in brown tape.give the whole thing a good coat of wax (i used floor wax).cover with two layers of 160 grams / sq.metre glass cloth then a layer of 80 gram s/ sq.metre cloth.leave that to cure for a bit.then cover the whole thing in epoxy/microballoon.when thats dry sand most of it off to get a smooth finish.you may have to add some more epoxy/microballoons in certain spots and sand again to get a good finish.
Paul Janssens explanes the method on his site http://www.pjmodelclassics.be/
Lockheed U2r PSS
« Reply #3 on: May 24, 2006, 23:54:46 PM »
Ok.so foam blocks cut for the wings and tail.hopefully cut the wings tomorrow.
Lockheed U2r PSS
« Reply #4 on: May 25, 2006, 07:37:39 AM »
Looking Very good Joe !!
Lockheed U2r PSS
« Reply #5 on: May 26, 2006, 16:56:16 PM »
wings,elevator and vertical stab cut.spar,wing tube and obechi covering next  :D
a little bit rough at the root.the cutter was just big enough(1 metre).should be fine
Lockheed U2r PSS
« Reply #6 on: May 26, 2006, 17:03:24 PM »
Nice work !
It's looking really good now !  Looks like a U2 now !   :D
Lockheed U2r PSS
« Reply #7 on: May 26, 2006, 17:27:41 PM »
hummm, i'm tempted by the back scheme aswell  :?
Lockheed U2r PSS
« Reply #8 on: May 26, 2006, 17:46:30 PM »
Yep, that's a nice one too
Or go for the full options : Black scheme, External tanks, and radar on the back ! :
Or silver (proto) :
Or for training :
Hope you are confused now !!   :D
Lockheed U2r PSS
« Reply #9 on: May 26, 2006, 20:28:43 PM »
Looks sweet Joe. I always liked the U2 too. Might build one myself one day. Although I prefer the black paint scheme (I think its a militry scheme, right?).
Lockheed U2r PSS
« Reply #10 on: June 15, 2006, 00:03:32 AM »
ok so i haven't done much work on the U2 lately due to nice sunny weather,lots of other work that needed doin and the feckin world cup thats been distracting me.
spars top and bottom,wing joiner tube and incidence pin tube done.nearly ready for covering.
cut some servo bays aswell!
Lockheed U2r PSS
« Reply #11 on: June 15, 2006, 07:58:27 AM »
Very nice Joe !
Almost finish !  :D   And stop watching the World Cup ! That's not good for you ! :D
By the way, did you start to put the sheeting on the wings ?
Lockheed U2r PSS
« Reply #12 on: June 15, 2006, 12:58:30 PM »
hey Fred.no haven't started the sheeting yet.need to cut the front off the leading edges for the balsa.cut the roots of the wings to fit the fuselage and fit the servo cable first.
hope to get started with the sheeting tonight.
Lockheed U2r PSS
« Reply #13 on: July 06, 2006, 09:04:57 AM »
Hi Joe. Any progress on the U2. It should make a great PSS plane.
Lockheed U2r PSS
« Reply #14 on: July 07, 2006, 22:02:24 PM »
hiya Alan.haven't had a chance to do much on the U2 for a while.i plan on putting a full day in on it tomorrow.i shall post some pictures of my progress tomorrow evening.i hope!
